i buy new AVRISP mkII for 2 day ago.
And after trying in many hours i get the same
error.
No target was detected. Ensure that target has power
I search in googel and here to find correct form for connect IC to AVRISP, and im sure is connect correcty.
But the same error message.
(i have AtMega16 and set ISP frequency very low),
Now i tryed with my voltmeter and check about AVRISP have volt for outside.
I tryed pin VCC and GND for 5+ but nothing show in my voltmeter.
I try the all other pin, but no respons.
I open the AVRISP box, and remove the connector cabel and calibrate plugg on AVRISP, but same, 0V.
I tryed USB plugg (innput), the was 5V+.
The green led and red led is on.
So AVRISP have voltage,
but not to output.
are my AVRISP broken?
I have orginal AVRISP mkII, and very new!
