hi all
i m trying to connect the atmel in slave mode. i hav a program dat runs on it for both slave reciver and transmitter.. i m trying to connect it to the lego mindstorm using the i2c interface. i am able to do the slave reciver mode but i m not able to do the salve transmitter mode..
the problem i face is this.. wen i start the devices it transmit for once and than the data line goes blank to transmiit again i hav to restart the atmel.. i m using CRO to see the wave forms... wat i find is wen i try to write to atmel the adrres sent from the device is 00100000.. it works right in wat ever mode i send it but wen i try to read from atmel it send the addres 00100001 and atmel stops responding and i coonote see any wave form onthe CRO its goes to staright line.
wat could b the problem???/
