watchdog interrupt atmega644 not working
11 posts / 0 new
I try to use a watchdog to get interrupts, no reset,
but it is not working at all.
My code to initialize:
void wd_start(void)
wdt_reset();
MCUSR &= ~(1<<WDRF);
WDTCSR |= (1<<WDCE) | (1<<WDE); //needed by manual p 50
WDTCSR = 68; // = WDIE=1, WDP2=1, WDE=0 (no reset)
return;
There is no effect, but if I use
wdt_enable(WDTO_120MS) (from wdt.h (WinAVR-gcc)
is it working.
However I can't use wdt.h, because I have to set WDIE and to clear WDE in order to get interrupts and this is not possible in wdt.h
What is wrong in my code?
How can I configure the atmega 644 to get interrupts?
Thank in advance
BMW freak
Are you enabling interrupts??
WDTON fuse is unprogrammed?
Compiler optimizations are enabled, so the generated code fulfills the timing requirements?
Stefan Ernst
How are you determining that? If you say "simulator" then take a peek at the manual - there's every chance it does not simulate the watchdog interrupt mechanism correctly (though sim2 is likely to be better than sim1 and it probably support 644P)
Here's an alternate to wdt.h with irq modes support-
http://www.mtcnet.net/~henryvm/wdt/
Not yet, but after your post did I insert sei(),
and it works! Wunderbar!
Many thanks from the old Europe (without any Edelweiß too)
BMWfreak
It seems to be very useful, I will try it,
thank you
The compiler optmiziation is unchanged from my "normal" mode. For a short time I was thinking, the compiler could manipulate the code for not fulfilling the 4-cycle-condition.
But the function after inserting sei(); is a compiler rehabitation.
many tx
bmwfreak
many tx
bmwfreak
Many thanks from the old Europe (wihtout Edelweiß too)
BMWfreak
I did not simulate it. In the program are markers so I can see where the program is.
BMWfreak
