USB flash memory stick
3 posts / 0 new
Hi there,
I have made a device that collects data and i want to save them via a USB connector to a USB memory stick.
How can i do that? any suggestions?
Thanks.
Base the design around an OTG chip such as AT90USB1287 perhaps?
If you are talking about programming 8 bit micros you may find it 1,000 times easier to use SD/MMC as a "PC friendly" flash storage as the interface and software is fairly trivial (especially given FatFs)
Yes AT90USB647 and AT90USB1287 are currently the only two AVR's with USB On-The-Go (OTG). The other USB AVR's without OTG support can't be used to host a USB device, they only work as slaves connected to a PC master.
If you want to use one of these AVR USB OTG devices, check out the open source LUFA (Lightweight USB Framework for AVRs): http://www.fourwalledcubicle.com...
But as mentioned it's simpler to use use an SD/MMC-card isntead.
If it's because you need to transfer the memory to a PC, many desktops and latops has built-in in SD/MMC-card reader. Otherwise you can buy a cheap reader to plug in the USB port.
