UC3A handle_bus_error_data_ftech
8 posts / 0 new
Hi all,
We have a strange problem that is not easy to figure.
We use FreeRTOS ans some time (1 reset of 5) I jump to _handle_bus_error_data_fetch handler
I try to determine what could be the problem and I doesn't seem to be very easy to get the offending piece of code.
I have an JTAG MKII interface.
Is it possible to have an Idea of what could be the problem ?
I pause the debug session when this happen, and I check the PC + 0x08 to see what is the PC was and it's in the div asm files.
I'm pretty sure i'm not doing the right thing now to get what i'm looking for.
What can cause this kind of exception ? The Tech manual is not really detail fot that exception
Regards
Jonathan
anyone ?
idea ?
Jonathan
Can you run the freeRTOS demo from the framework and make it _not_ crash?
-sma
Yes I can make the demo without crashing. The problem is when I reset my board if the program start correctly it run forever without crashing. Some time When I reset the CPU, it crash and jump to this handler.
Really hard to find where could be the problem.
if the program is always crashing, i could identify it but whith this issue it's very hard.
Regards
Jonathan
When it crashes, can you halt and dump the stack?
You should be able to see the offending address (see in SP+4 location).
-sma
yes I can do this. It's in newlib malloccr.c line 2645. (Free function).
but if I change the code a little bit, I got another address...
very strange.
Jonathan
What is the version of your chip and what is your clock speed?
I have a Rev I and a speed of 48Mhz with 1 wait state.
We have some something in our code about Freeing a bad pointer.
So I keep you updated when we find why.
regards
Jonathan
