PORTA interrupting?
5 posts / 0 new
Hi Freaks,
I'm developing a stepper position controll for theater performance. The group has a special kitchen cabinet. It has 10 movable walls in it. Each wall carrys like 200 photo slides. At the back is a strong light which projects the photo slides to a wall.
The aim is to position the wooden walls via 5 pushbuttons. Each button represents one position. (yai, they'll have 50 buttons ... but it's needed fast and cheap)
While the motor moves to a position a busy LED is turned on and the buttons shall have no effect. I'm using 9V/1A 1,8° steppers and clock/direction drivers (SMC11). There will be 10 walls driven by 10 steppers and 5 micros.
µC: right now M644; final ones will be M16
language: C
board: now STK500, self and hand made ones later
I got everything pretty good working right now, but PORTA makes me problems. When I connect the STK500 switches to it the buttons do effect the µC while the motor moves. When I use PORTD everything is fine.
I'm pretty sure I disabled all PORTA alternate functions but well, this is my first AVR C-Project. Please have a look at my code, maybe you get it. Other comments on my code are welcome.
void init (void)
//[Timer1]
    PRR CLEAR_BIT3;      //clear Powerreduction for Timer1
    TCNT1  = 0x00;
    TCCR1A = 0x00;       //normal mode
    TCNT1 = 0xFF00;
    #define ON_T1 0x02   //define prescaler for TIM2 here
                         //Set up timer at Fcpu/8
//[PortA]
    DDRA   = 0b11100000;  //PA0..4 switches for M0, PA5..7 LEDs for M0
    PINA   = 0x00;
//[ADC]
    ADCSRA = 0x00;       //
    DIDR0  = 0x00;       //disable ADC
//[Analog Comparator]
    ADCSRB = 0x00;       //
    ACSR   = 0b10010001; //disable analog comparator
    DIDR1  = 0x00;       //
//some more init
//[Interrupts]
    TIFR1  = 0xFF;      //clear TIM1 interrupt flags
    TIMSK1 = 0x01;      //Enable overflow interrupt
    Timer1(ON_T1);
    sei();
ISR(TIMER1_OVF_vect)
//some code
int main()
    init();
        if(ui8_PositionReady_M0 == READY)
            cli();//make writing to ui16_SCreq_M0 atomic
            switch ( ((~PINA) & 0b00011111) )//mask away LED Bits
                case (Bit0):
                        ui16_SCreq_M0 = ui16_Pos0_M0;
                        LookBusy_M0();
                        Stepper_M0(ENABLE);
                        break;
                case (Bit1):
                        ui16_SCreq_M0 = ui16_Pos1_M0;
                        LookBusy_M0();
                        Stepper_M0(ENABLE);
                        break;
                case (Bit2):
                        ui16_SCreq_M0 = ui16_Pos2_M0;
                        LookBusy_M0();
                        Stepper_M0(ENABLE);
                        break;
                case (Bit3):
                        ui16_SCreq_M0 = ui16_Pos3_M0;
                        LookBusy_M0();
                        Stepper_M0(ENABLE);
                        break;
                case (Bit4):
                        ui16_SCreq_M0 = ui16_Pos4_M0;
                        LookBusy_M0();
                        Stepper_M0(ENABLE);
                        break;
                default:break;
            sei();
        else {}
PS:
LookBusy_M0();
sets ui8_PositionReady_M0 to NOT_READY. The TIM1 ISR sets it READY when position is arrived.
Quick notes:
Setting PINx to anything is useless. PINx is the input value from the port, while PORTx is the output value. It might make sense to set PORTx bit to 1 when a pin is defined as input, since most new AVR processors will then put a weak pull-up resistor to VCC.
There is not a DIDR1 register in the ATMega644. I'm surprised you are not getting a compiler error on that statement.
You don't show the definition of ui8_PositionReady_M0 - can it be changed inside an interrupt? If so, add the keyword volatile to it's definition. My guess is that this is the true problem.
Stu
Sorry to be a pedant but in modern AVRs writing 1 bits to PINA toggles the output state of the respective pins that are set to output in the DDRA. However I agree that "PINA=0x00" is pointless.
from ATmega644/V Preliminary, p.232
20.3.3 DIDR1 – Digital Input Disable Register 1
All global variables are declared volatile (can this be a disadvantage?)
PINA writig deleted ^^
