Hi Freaks,
I have been trying to get my LCD working for a long time. I am using the simplest possible setup. I am using Johann Ekdahl's code as follows:
/* Simple LCD character display module demonstrator using the 4-bit interface. No handling of the busy flag is done - all timing contraints are handled by delay loops. * This code should be good to run at up to 8 MHz. * Above that you might have to tweak the timing of things including, but not restricted to, the existing delays. */ #include#include /* Here are some defines for the data connections, * DB4..7 on the LCD display module. These should be wired * up to the four high pins of any port A..D. You need to alter * these to fit your wire up of your display. */ #define LCD_DATA_PORT PORTD #define LCD_DATA_DDR DDRD /* Here are some defines for the control connections * (RS, R/W and E on the LCD display module). These can be wired * to any pins on any port A..D (all to the same port though). * You need to alter these to fit your wire up of your display. */ #define LCD_CTRL_PORT PORTD #define LCD_CTRL_DDR DDRD #define LCD_RS 2 #define LCD_RW 3 #define LCD_E 4 /* * YOU SHOULD NOT NEED TO ALTER ANYTHING BEYOND THIS POINT! * * This holds as long as you have the four data signals * connected to the upper 4-bit nibble of the AVR port, * and you run at a maximum frequency of 8 MHz. */ /* Here are some defines for the LCD instructions we'll use. */ #define LCD_FUNCTION_SET 0x38 // 0b00110000 #define LCD_FUNCTION_SET_4BIT 0x28 // 0b00101000 #define LCD_DISPLAY_OFF 0x08 // 0b00001000 #define LCD_DISPLAY_ON 0x0F // 0b00001111 #define LCD_DISPLAY_CLEAR 0x01 // 0b00000001 #define LCD_ENTRY_MODE_SET 0x06 // 0b00000110 #define LCD_CURSOR_HOME 0x02 // 0b00000010 /* LcdSendNibble * * Sends a 4-bit nibble to the display. * * Parameters: * uint8_t nibble The high nibble of of this byte * is sent to the display. * Returns: * nothing */ void LcdSendNibble( uint8_t nibble ) { _delay_ms(5); // Output upper nibble on the data ports upper bits LCD_DATA_PORT = (nibble & 0xF0) | (LCD_DATA_PORT & 0x0F); // Toggle the E line LCD_CTRL_PORT |= (1<<LCD_E); // Going up.. LCD_CTRL_PORT &= ~(1<<LCD_E); // ..and down. } /* LcdSendByte * * Sends a 8-bit byte to the display. * * Parameters: * uint8_t theByte The byte to send to the display * * Returns: * nothing */ void LcdSendByte(uint8_t theByte) { // Send the high nibble LcdSendNibble(theByte); // Shift theByte to get lower nibble in upper part... theByte = theByte << 4; // ...and send it LcdSendNibble(theByte); } /* LcdSendInstruction * * Sends an instruction to the display. * * Parameters: * uint8_t command This byte is sent to the display as * an instruction (RS low). * Returns: * nothing */ void LcdSendInstruction( uint8_t theInstruction ) { // RS low for instructions LCD_CTRL_PORT &= ~(1<<LCD_RS); // Send the instruction LcdSendByte(theInstruction); } /* LcdSendCharacter * * Sends a character to the display. * * Parameters: * uint8_t nibble This byte is sent to the display as * a character (RS high). * Returns: * nothing */ void LcdSendCharacter(uint8_t theChar) { // RS high for characters to display LCD_CTRL_PORT |= (1<<LCD_RS); // Send the command LcdSendByte(theChar); } /* LcdInitialize * * Initialize the display. * * Parameters: * none * * Returns: * nothing */ void LcdInitialize(void) { // initialize LCD control lines LCD_CTRL_PORT &= ~(1<<LCD_RS); // RS low LCD_CTRL_PORT &= ~(1<<LCD_RW); // R/W low LCD_CTRL_PORT &= ~(1<<LCD_E); // E low // initialize LCD control lines to output LCD_CTRL_DDR |= (1<<LCD_RS); LCD_CTRL_DDR |= (1<<LCD_RW); LCD_CTRL_DDR |= (1<<LCD_E); // initialize LCD data port to input LCD_DATA_DDR |= 0xF0; // Data on high four bits of port for now... // First part of init sequence is 3 x Function Set with // stipulated waits. Note that the display is in 8-bit mode // initially, but although the four low data lines are not connected // this does not matter as the instructions low nibble is zero anyway. _delay_ms(15); LcdSendNibble( LCD_FUNCTION_SET ); _delay_ms(5); LcdSendNibble( LCD_FUNCTION_SET ); _delay_us(100); LcdSendNibble( LCD_FUNCTION_SET ); // Now, still in 8-bit mode, set the display to 4-bit mode LcdSendNibble( LCD_FUNCTION_SET_4BIT ); // We are now in 4-bit mode. // Do the rest of the init sequence. LcdSendInstruction( LCD_FUNCTION_SET_4BIT ); LcdSendInstruction( LCD_DISPLAY_OFF ); LcdSendInstruction( LCD_DISPLAY_CLEAR ); LcdSendInstruction( LCD_ENTRY_MODE_SET ); LcdSendInstruction( LCD_DISPLAY_ON ); } char message[] = "4-bit"; int main(void) { LcdInitialize(); DDRD = 0xFF; PORTD = 0xFF; volatile int i = 0; while (message[i] != 0) { LcdSendCharacter(message[i]); i++; } while(1); return 0; }
I have assigned everything to PortD. I have changed nothing in Johann's code except in main I have assigned port D (DDRD and PORTD )with 0xFF.
I am using an external crystal (8MHz) which I have confirmed the AVR is using.
Also everything else works fine with a simple test circuit (flashing an LED).
When I turn the power ON for my AVR, I see the blocks on my LCD on the first line. My LCD is a standard HD44780 driver type.
What am I missing?
Since I am using the four ports of Port D do I have to ground the unused pins on the LCD driver?
Is it maybe the delays that I have to tweak?
Any help appreciated. I have attached my schematic.
Thanks.
