hi all,
i have a doubt about the system clock speed for atmega 32L which mention in some of the tutorial or discussion.
i'm using atmega32L for my learning. so i add in a 4Mhz XTAL and coupling cap with it. From the datasheet, i know the maximum speed of atmega32L is 8Mhz. (correct me if i'm wrong). so after i add in the 4Mhz XTAL is it means that my system speed is 4Mhz now? because i'm not sure what is the input frequency i'm using when calculating the timer target count value.
thank you.
