Has anyone used avrdude on an xmega32a4? I just tried the latest, 5.6 version, and the configuration file does not have support for it. Does anyone have a configuration file that works with xmega32a4? I am a little leery of creating my own entry in the configuration file.
xmega32a4 avrdude
Level: Moderator
Posts: 97580 View posts
Does avrdude even do PDI yet?
EDIT well OK the word "PDI" gets one mention in the manual under the decription of "-c stk600" so it seems it maybe does.
I added the following to my avrdude.conf which seams to work
#------------------------------------------------------------ # ATxmega32A4 #------------------------------------------------------------ part id = "x32a4"; desc = "ATXMEGA32A4"; signature = 0x1E 0x95 0x41; has_jtag = yes; has_pdi = yes; nvm_base = 0x01C0; memory "eeprom" page_size = 32; size = 1024; ; memory "flash" size = 0x8000; page_size = 256; ; memory "boot" size = 0x1000; page_size = 256; ; # signature is actually in IO address space memory "signature" size = 3; offset = 0x90; ; memory "fuse0" size = 1; offset = 0x20; ; memory "fuse1" size = 1; offset = 0x21; ; memory "fuse2" size = 1; offset = 0x22; ; memory "fuse4" size = 1; offset = 0x24; ; memory "fuse5" size = 1; offset = 0x25; ; memory "lockbits" size = 1; offset = 0x27; ; memory "calibration" size = 512; ; memory "usersig" size = 512; offset = 0x200; ; ;
an xmega32a4
Do you really have a supply of the little beasties? Samples, or through distribution?
Lee
