Structured exceptions in C in avr-gcc?
16 posts / 0 new
Do you, avr-gcc experts, have any tricks, recommendations etc. how to achieve structured exceptions (try-catch-finally-anything) in C in avr-gcc?
JW
Switch to C++ perhaps ? ;-)
Humm.
Okay, and how smooth/rough such transition might be, provided that I don't intend to use objects?
JW
I'll leave it for others to comment (Johan?) as I stay well clear of the mysterious black art myself.
That did not sound like an encouragement... ;-)
Right now, I am using a combination of a label at the place where "finally" would come, and very carefully used goto-s as the exceptions. The natural drawback is, that I can't really "throw an exception" in called routines and have to "propagate" the error using global variables, which is rather cumbersome.
I though I am not the only one who encounters this from time to time as a real life problem...
JW
I think this has been discussed at length in several threads. The forums search mechanism does not like the term "C++", but "exception handling" might work. You might also try the C++ sticky at the top of this form (you probably already did).
I also am not quite sure why it is not implemented, or how to handle it. My vague memories of the discussions centered on stack issues but I could be way off base here.
The common answer for newbies is, "don't do that -- you'll hurt yourself", but experienced people may have a better answer in store for them.
Stu
try-catch-finally syntax is C++. For the C language version of that stuff, look into setjmp and longjmp which are found in , which is a standard C header file. You can find out more about it in the avr-libc user manual:
Wow. Exactly the "don't do that" stuff, as it seems. There are days when I like just that... ;-)
Thanks a lot.
Jan
I've been driving it so hard that I'm the one mentioned? Oh dear...
Generally speaking, you should be able to compile C code with a C++ compiler and get the same result (or at least get generated code that has the same semantics). There are some places where C++ isn't backwards compatible with C (syntactically or semantically). As so often Google and Wikipedia is a great help:
http://en.wikipedia.org/wiki/Com...
If you are truly interested in the subject then put "C++ compatibility C" into Google and start exploring and reading.
Well think hard what does try and catch do, and can you rewrite the functionality somehow, with macros or functions etc.
That's a (resemblance of :-) ) good news.
This is exactly what I am eager to avoid.
EW opened new horizons to me with the setjmp stuff. I looked at the .S and found out that it's similar to what I was planning to write in the near future. As so often, I considered reinvention of the wheel.
Maybe a bit more cumbersome to use than try-finally, but it fulfills my expectations enough to avoid C++ for now.
JW
setjmp is high overhead versus a goto
Sure, but it also has a different functionality.
Right now, from called/nested routines, I have to "propagate" an error "manually" via setting a global variable and a set of gotos and labels. setjmp() allows me to "jump out" from a nested set of routines right to the error processing.
This is a canonical example of exchanging efficiency for convenience.
JW
setjmp to fly off to a totally different function would be very confusing. Not what I'd do to clearly show exiting from nested loops within a single function.
steve, steve, steve.
setjmp/longjmp are described as "non-local goto". Of course they are high overhead. Of course it is very confusing. But that is what they are designed to do, and they are also standard C library functions, and have been around for a long time. They were designed for exactly this reason: exception handling. It's just that C++ has a cleaner design with try-catch constructs.
I was going to post something along "I have concocted a pseudo __try/__finally/__throw using setjmp/longjmp", but I got frustrated by how I am unable to post a left bracket - exclamation mark - left bracket sequence.
Is it a known bug of this forum, or is it me?
JW
