AVR butterfly using keypad 4x4
9 posts / 0 new
Hello Dean!
I'm newbei and i'm using keypad as input to my butterfly.
i tried to display on my butterfly lcd based on what i've key in from the keypad.
any ideas how this could be works??
This is my keypad 4x4 AVR-GCC C language:
#include
int main()
//high nibble for output(columns) low for input(rows);
DDRB=0xF0;
//enable internal pullups for PB0-PB3
PORTB=0x0F;
//Port D for indication only
DDRD=0xFF;
while (1) //loop key check forever
//first column
PORTB =0b01111111;
//check for rows and send key number to portD
//instead sending key number to PORTD you can use
// any function that serves pressed button
if (bit_is_set(PINB, 3)) PORTD=1;
if (bit_is_set(PINB, 2)) PORTD=2;
if (bit_is_set(PINB, 1)) PORTD=3;
if (bit_is_set(PINB, 0)) PORTD=4;
//second column
PORTB =0b10111111;
if (bit_is_set(PINB, 3)) PORTD=5;
if (bit_is_set(PINB, 2)) PORTD=6;
if (bit_is_set(PINB, 1)) PORTD=7;
if (bit_is_set(PINB, 0)) PORTD=8;
//third column
PORTB =0b11011111;
if (bit_is_set(PINB, 3)) PORTD=9;
if (bit_is_set(PINB, 2)) PORTD=10;
if (bit_is_set(PINB, 1)) PORTD=11;
if (bit_is_set(PINB, 0)) PORTD=12;
//fourth column
PORTB =0b11101111;
if (bit_is_set(PINB, 3)) PORTD=13;
if (bit_is_set(PINB, 2)) PORTD=14;
if (bit_is_set(PINB, 1)) PORTD=15;
if (bit_is_set(PINB, 0)) PORTD=16;
Please help me to display any character on my lcd. :cry:
I'm newbei
Then the first thing you should do is read the forum guidelines so that you know which of forums this post belongs in.
Steve A.
i'm currently found code for my keypad
when i compile it, there is an error
c:/winavr/bin/../lib/gcc/avr/4.1.1/../../../../avr/lib/avr5/crtm169.o:(.init9+0x0): undefined reference to `main'
what does it mean??
That you don't have a function anywhere in your program called main() which is a bit of a shame as that's the entry point for all C programs.
For your next problem (once you get your build issues solved):
Take a look at your scan routines - you set one column low to select it and check for rows being high. Also, you have no debouncing there so you will likely get multiple outputs for each keypress and release.
i try tu put main() but still have error
FYI, im using dean's keypad program
Not in the C file posted below that quote you didn't. It contains on a single function called KPDScan(). Either rename that to main() or add a short main() that invokes that function.
hi there
i found a c program for keypad from internet but the keypad is connected to other microcontroller, not butterfly
my question is can i use this program and run it with avr studio?
thanks
Probably not without some changes, but we really can't tell until you show the code.
It sounds like you are trying too much here. Start by getting an LED to blink at the correct rate. This will make sure you know how to write, compile, link, and load programs.
Then work on getting the LCD or serial port running so you have some way of getting debug output from your code.
Then finally, add the keypad code. The code you have at the beginning of this thread isn't too bad of a first start *if* you fix the bugs in it. Once it works, you can add debouncing, but first get the basic version going.
/mike
