working with internal SRAM
5 posts / 0 new
Hello, avr-freaks!
Thanks so much for the feedback with my first question!
I now have a simple question I guess that could be solved in no time:
1) I'm using SRAM (addresses $20 to $28) to store some data (9 bytes);
2) I'm storing these bytes using STS (sts $20,r2...);
3) I'm trying to retrive value from address $20;
BUT
* I can't retrieve that value at the $20 address, for I'm trying to use a variable (r24 to store the address in the SRAM from which to retrieve data in current cycle).
* I'm using lds with immediate address value - this works ok, but how to use variable?
Dmitry.
admin's test signature
The internal RAM starts at address $60.
Location $20 is actually an I/O address which is probably why you are having problems.
Do you have a .org directive in your data segment? (For example:
.dseg
.org $20
.byte variable1
.byte variable2
etc.)
If so, you can probably remove it:
.dseg
.byte variable1
.byte variable2
Sean.
Hmmm, so with which address should I start?
What's the best addresses range to use?
Accoding to the manual, data memory addresses are
$0-$1F 32 general purpose registers
$20-$5F 64 I/O registers
$60- Internal SRAM
Laurence Boyd II
Thanks a lot!
well, i figured out that i should use SRAM starting from $60 bu this explains all the rest.
Dmitry.
