Compiling and Programming an EVK1101 using custom Makefile
2 posts / 0 new
Hi all,
I'm just starting out in the AVR32 world, after becoming reasonably established in the art of AVR8 programming. Yesterday I received a new EXK1101 board, which I'm now trying to work out how to program. My first goal is to get the board LEDs up and working, so I can move on to other systems.
I'm trying to use only the standalone toolchain, without the AVR32 UC3B framework or AVR32Studio (except for debugging, in the latter case). I'm also trying to modify a standard WinAVR (AVR8) makefile to support compilation to either AVR8 or AVR32 targets.
Note: lengthy fragments follow, but most can be ignored - I'm just trying to give all output to help debug my problem.
This is my current test program:
	// External 8MHz+ crystal connected
	AVR32_PM.OSCCTRL0.mode = 7;
	// Startup time 142ms
	AVR32_PM.OSCCTRL0.startup = 6;
	// Enable OSC0
	AVR32_PM.MCCTRL.osc0en = true;
	// Wait for OSC0 to be ready
	while (!(AVR32_PM.POSCSR.osc0rdy));
	// Select OSC0 as the main clock source
	AVR32_PM.MCCTRL.mcsel = 1;
	AVR32_GPIO.port[0].gpers = (1UL << 7);
	AVR32_GPIO.port[0].oders = (1UL << 7);
	AVR32_GPIO.port[0].ovrs  = (1UL << 7);
	for (;;)
And my makefile:
# Hey Emacs, this is a -*- makefile -*-
# WinAVR Makefile Template written by Eric B. Weddington, Jörg Wunsch, et al.
#  >> Modified for use with the LUFA project. <<
# Released to the Public Domain
# Additional material for this makefile was written by:
# Peter Fleury
# Tim Henigan
# Colin O'Flynn
# Reiner Patommel
# Markus Pfaff
# Sander Pool
# Frederik Rouleau
# Carlos Lamas
# Dean Camera
# Opendous Inc.
# Denver Gingerich
# On command line:
# make all = Make software.
# make clean = Clean out built project files.
# make coff = Convert ELF to AVR COFF.
# make extcoff = Convert ELF to AVR Extended COFF.
# make program = Download the hex file to the device, using avrdude.
#                Please customize the avrdude settings below first!
# make dfu = Download the hex file to the device, using dfu-programmer (must
#            have dfu-programmer installed).
# make flip = Download the hex file to the device, using Atmel FLIP (must
#             have Atmel FLIP installed).
# make dfu-ee = Download the eeprom file to the device, using dfu-programmer
#               (must have dfu-programmer installed).
# make flip-ee = Download the eeprom file to the device, using Atmel FLIP
#                (must have Atmel FLIP installed).
# make doxygen = Generate DoxyGen documentation for the project (must have
#                DoxyGen installed)
# make debug = Start either simulavr or avarice as specified for debugging,
#              with avr-gdb or avr-insight as the front end for debugging.
# make filename.s = Just compile filename.c into the assembler code only.
# make filename.i = Create a preprocessed source file for use in submitting
#                   bug reports to the GCC project.
# To rebuild project do "make clean" then "make all".
# Architecture name. This must be one of the following values:
#	avr8   =   8-bit AVRs
#   avr32  =   32-bit AVRs
#   arm    =   ARM based microcontrollers
#ARCH = avr8
ARCH = avr32
# MCU name
#MCU = at90usb1287
MCU = uc3b0256
# Target board (see library BoardTypes.h documentation, USER or blank for projects not requiring
# LUFA board drivers). If USER is selected, put custom board drivers in a directory called
# "Board" inside the application directory.
#BOARD  = USBKEY
BOARD = EVK1101
# Processor frequency.
#     This will define a symbol, F_CPU, in all source code files equal to the
#     processor frequency. You can then use this symbol in your source code to
#     calculate timings. Do NOT tack on a 'UL' at the end, this will be done
#     automatically to create a 32-bit value in your source code.
#     Typical values are:
#         F_CPU =  1000000
#         F_CPU =  1843200
#         F_CPU =  2000000
#         F_CPU =  3686400
#         F_CPU =  4000000
#         F_CPU =  7372800
#         F_CPU =  8000000
#         F_CPU = 11059200
#         F_CPU = 14745600
#         F_CPU = 16000000
#         F_CPU = 18432000
#         F_CPU = 20000000
F_CPU = 8000000
# Input clock frequency.
#     This will define a symbol, F_CLOCK, in all source code files equal to the
#     input clock frequency (before any prescaling is performed). This value may
#     differ from F_CPU if prescaling is used on the latter, and is required as the
#     raw input clock is fed directly to the PLL sections of the AVR for high speed
#     clock generation for the USB and other AVR subsections. Do NOT tack on a 'UL'
#     at the end, this will be done automatically to create a 32-bit value in your
#     source code.
#     If no clock division is performed on the input clock inside the AVR (via the
#     CPU clock adjust registers or the clock division fuses), this will be equal to F_CPU.
F_CLOCK = 8000000
# Output format. (can be srec, ihex, binary)
FORMAT = ihex
# Target file name (without extension).
TARGET = BoardTest
# Object files directory
#     To put object files in current directory, use a dot (.), do NOT make
#     this an empty or blank macro!
OBJDIR = .
# List C source files here. (C dependencies are automatically generated.)
SRC = $(TARGET).c
# List C++ source files here. (C dependencies are automatically generated.)
CPPSRC =
# List Assembler source files here.
#     Make them always end in a capital .S.  Files ending in a lowercase .s
#     will not be considered source files but generated files (assembler
#     output from the compiler), and will be deleted upon "make clean"!
#     Even though the DOS/Win* filesystem matches both .s and .S the same,
#     it will preserve the spelling of the filenames, and gcc itself does
#     care about how the name is spelled on its command-line.
ASRC =
# Optimization level, can be [0, 1, 2, 3, s].
#     0 = turn off optimization. s = optimize for size.
#     (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
OPT = s
# Debugging format.
#     Native formats for AVR-GCC's -g are dwarf-2 [default] or stabs.
#     AVR Studio 4.10 requires dwarf-2.
#     AVR [Extended] COFF format requires stabs, plus an avr-objcopy run.
DEBUG = dwarf-2
# List any extra directories to look for include files here.
#     Each directory must be seperated by a space.
#     Use forward slashes for directory separators.
#     For a directory that has spaces, enclose it in quotes.
EXTRAINCDIRS = ../../
# Compiler flag to set the C Standard level.
#     c89   = "ANSI" C
#     gnu89 = c89 plus GCC extensions
#     c99   = ISO C99 standard (not yet fully implemented)
#     gnu99 = c99 plus GCC extensions
CSTANDARD = -std=gnu99
# Place -D or -U options here for C sources
CDEFS  = -DF_CPU=$(F_CPU)UL -DF_CLOCK=$(F_CLOCK)UL -DBOARD=BOARD_$(BOARD)
CDEFS += -DUSE_NONSTANDARD_DESCRIPTOR_NAMES -DNO_STREAM_CALLBACKS -DUSB_DEVICE_ONLY
CDEFS += -DUSE_STATIC_OPTIONS="(USB_DEVICE_OPT_FULLSPEED | USB_OPT_REG_ENABLED | USB_OPT_AUTO_PLL)"
# Place -D or -U options here for ASM sources
ADEFS = -DF_CPU=$(F_CPU)
# Place -D or -U options here for C++ sources
CPPDEFS = -DF_CPU=$(F_CPU)UL
#CPPDEFS += -D__STDC_LIMIT_MACROS
#CPPDEFS += -D__STDC_CONSTANT_MACROS
#---------------- Compiler Options C ----------------
#  -g*:          generate debugging information
#  -O*:          optimization level
#  -f...:        tuning, see GCC manual and avr-libc documentation
#  -Wall...:     warning level
#  -Wa,...:      tell GCC to pass this to the assembler.
#    -adhlns...: create assembler listing
CFLAGS = -g$(DEBUG)
CFLAGS += $(CDEFS)
CFLAGS += -O$(OPT)
CFLAGS += -funsigned-char
CFLAGS += -funsigned-bitfields
CFLAGS += -ffunction-sections
CFLAGS += -fpack-struct
CFLAGS += -fshort-enums
CFLAGS += -finline-limit=20
CFLAGS += -Wall
CFLAGS += -Wstrict-prototypes
#CFLAGS += -mshort-calls
CFLAGS += -Wundef
#CFLAGS += -fno-unit-at-a-time
#CFLAGS += -Wunreachable-code
#CFLAGS += -Wsign-compare
CFLAGS += -Wa,-adhlns=$(<:%.c=$(OBJDIR)/%.lst)
CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
CFLAGS += $(CSTANDARD)
#---------------- Compiler Options C++ ----------------
CPPFLAGS = -g$(DEBUG)
CPPFLAGS += $(CPPDEFS)
CPPFLAGS += -O$(OPT)
CPPFLAGS += -funsigned-char
CPPFLAGS += -funsigned-bitfields
CPPFLAGS += -fpack-struct
CPPFLAGS += -fshort-enums
CPPFLAGS += -fno-exceptions
CPPFLAGS += -Wall
CFLAGS += -Wundef
#CPPFLAGS += -mshort-calls
#CPPFLAGS += -fno-unit-at-a-time
#CPPFLAGS += -Wstrict-prototypes
#CPPFLAGS += -Wunreachable-code
#CPPFLAGS += -Wsign-compare
CPPFLAGS += -Wa,-adhlns=$(<:%.cpp=$(OBJDIR)/%.lst)
CPPFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
#CPPFLAGS += $(CSTANDARD)
#---------------- Assembler Options ----------------
#  -adhlns:   create listing
#  -gstabs:   have the assembler create line number information; note that
#             for use in COFF files, additional information about filenames
#             and function names needs to be present in the assembler source
#             files -- see avr-libc docs [FIXME: not yet described there]
#  -listing-cont-lines: Sets the maximum number of continuation lines of hex
#       dump that will be displayed for a given single line of source input.
ASFLAGS = $(ADEFS) -Wa,-adhlns=$(<:%.S=$(OBJDIR)/%.lst),-gstabs,--listing-cont-lines=100
#---------------- Library Options ----------------
# Minimalistic printf version
PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min
# Floating point printf version (requires MATH_LIB = -lm below)
PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt
# If this is left blank, then it will use the Standard printf version.
PRINTF_LIB =
#PRINTF_LIB = $(PRINTF_LIB_MIN)
#PRINTF_LIB = $(PRINTF_LIB_FLOAT)
# Minimalistic scanf version
SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min
# Floating point + %[ scanf version (requires MATH_LIB = -lm below)
SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt
# If this is left blank, then it will use the Standard scanf version.
SCANF_LIB =
#SCANF_LIB = $(SCANF_LIB_MIN)
#SCANF_LIB = $(SCANF_LIB_FLOAT)
MATH_LIB = -lm
# List any extra directories to look for libraries here.
EXTRALIBDIRS =
#---------------- External Memory Options ----------------
# 64 KB of external RAM, starting after internal RAM (ATmega128!),
# used for variables (.data/.bss) and heap (malloc()).
#EXTMEMOPTS = -Wl,-Tdata=0x801100,--defsym=__heap_end=0x80ffff
# only used for heap (malloc()).
#EXTMEMOPTS = -Wl,--section-start,.data=0x801100,--defsym=__heap_end=0x80ffff
EXTMEMOPTS =
#---------------- Linker Options ----------------
#  -Wl,...:     tell GCC to pass this to linker.
#    -Map:      create map file
#    --cref:    add cross reference to  map file
LDFLAGS = -Wl,-Map=$(TARGET).map,--cref
LDFLAGS += -Wl,--relax
LDFLAGS += -Wl,--gc-sections
LDFLAGS += $(EXTMEMOPTS)
LDFLAGS += $(patsubst %,-L%,$(EXTRALIBDIRS))
LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB)
#LDFLAGS += -T linker_script.x
#---------------- Programming Options (avrdude) ----------------
# Programming hardware: alf avr910 avrisp bascom bsd
# dt006 pavr picoweb pony-stk200 sp12 stk200 stk500
# Type: avrdude -c ?
# to get a full listing.
AVRDUDE_PROGRAMMER = jtagmkII
# com1 = serial port. Use lpt1 to connect to parallel port.
AVRDUDE_PORT = usb
AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
#AVRDUDE_WRITE_EEPROM = -U eeprom:w:$(TARGET).eep
# Uncomment the following if you want avrdude's erase cycle counter.
# Note that this counter needs to be initialized first using -Yn,
# see avrdude manual.
#AVRDUDE_ERASE_COUNTER = -y
# Uncomment the following if you do /not/ wish a verification to be
# performed after programming the device.
#AVRDUDE_NO_VERIFY = -V
# Increase verbosity level.  Please use this when submitting bug
# reports about avrdude. See
# to submit bug reports.
#AVRDUDE_VERBOSE = -v -v
AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY)
AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE)
AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER)
#---------------- Debugging Options ----------------
# For simulavr only - target MCU frequency.
DEBUG_MFREQ = $(F_CPU)
# Set the DEBUG_UI to either gdb or insight.
# DEBUG_UI = gdb
DEBUG_UI = insight
# Set the debugging back-end to either avarice, simulavr.
DEBUG_BACKEND = avarice
#DEBUG_BACKEND = simulavr
# GDB Init Filename.
GDBINIT_FILE = __avr_gdbinit
# When using avarice settings for the JTAG
JTAG_DEV = /dev/com1
# Debugging port used to communicate between GDB / avarice / simulavr.
DEBUG_PORT = 4242
# Debugging host used to communicate between GDB / avarice / simulavr, normally
#     just set to localhost unless doing some sort of crazy debugging when
#     avarice is running on a different computer.
DEBUG_HOST = localhost
ifeq ($(ARCH),avr8)
	TOOL_PREFIX = avr-
	MCU_PARAM   = -mmcu=$(MCU)
	FLIP_PREFIX =
else ifeq ($(ARCH),avr32)
	TOOL_PREFIX = avr32-
	MCU_PARAM   = -mpart=$(MCU)
	FLIP_PREFIX = at32
else ifeq ($(ARCH),arm7)
	TOOL_PREFIX = arm-elf-
	MCU_PARAM   = -mcpu=$(MCU)
	FLIP_PREFIX =
endif
# Define programs and commands.
SHELL = sh
CC = $(TOOL_PREFIX)gcc
OBJCOPY = $(TOOL_PREFIX)objcopy
OBJDUMP = $(TOOL_PREFIX)objdump
SIZE = $(TOOL_PREFIX)size
AR = $(TOOL_PREFIX)ar rcs
NM = $(TOOL_PREFIX)nm
AVRDUDE = avrdude
REMOVE = rm -f
REMOVEDIR = rm -rf
COPY = cp
WINSHELL = cmd
# Define Messages
# English
MSG_ERRORS_NONE = Errors: none
MSG_BEGIN = -------- begin --------
MSG_END = --------  end  --------
MSG_SIZE_BEFORE = Size before:
MSG_SIZE_AFTER = Size after:
MSG_COFF = Converting to AVR COFF:
MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
MSG_FLASH = Creating load file for Flash:
MSG_EEPROM = Creating load file for EEPROM:
MSG_EXTENDED_LISTING = Creating Extended Listing:
MSG_SYMBOL_TABLE = Creating Symbol Table:
MSG_LINKING = Linking:
MSG_COMPILING = Compiling C:
MSG_COMPILING_CPP = Compiling C++:
MSG_ASSEMBLING = Assembling:
MSG_CLEANING = Cleaning project:
MSG_CREATING_LIBRARY = Creating library:
# Define all object files.
OBJ = $(SRC:%.c=$(OBJDIR)/%.o) $(CPPSRC:%.cpp=$(OBJDIR)/%.o) $(ASRC:%.S=$(OBJDIR)/%.o)
# Define all listing files.
LST = $(SRC:%.c=$(OBJDIR)/%.lst) $(CPPSRC:%.cpp=$(OBJDIR)/%.lst) $(ASRC:%.S=$(OBJDIR)/%.lst)
# Compiler flags to generate dependency files.
GENDEPFLAGS = -MMD -MP -MF .dep/$(@F).d
# Combine all necessary flags and optional flags.
# Add target processor to flags.
ALL_CFLAGS = $(MCU_PARAM) -I. $(CFLAGS) $(GENDEPFLAGS)
ALL_CPPFLAGS = $(MCU_PARAM) -I. -x c++ $(CPPFLAGS) $(GENDEPFLAGS)
ALL_ASFLAGS = $(MCU_PARAM) -I. -x assembler-with-cpp $(ASFLAGS)
# Default target.
all: begin gccversion sizebefore build checkhooks checklibmode sizeafter end
# Change the build target to build a HEX file or a library.
build: elf hex eep lss sym
#build: lib
elf: $(TARGET).elf
hex: $(TARGET).hex
eep: $(TARGET).eep
lss: $(TARGET).lss
sym: $(TARGET).sym
LIBNAME=lib$(TARGET).a
lib: $(LIBNAME)
# Eye candy.
# AVR Studio 3.x does not check make's exit code but relies on
# the following magic strings to be generated by the compile job.
begin:
	@echo
	@echo $(MSG_BEGIN)
end:
	@echo $(MSG_END)
	@echo
# Display size of file.
HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
ELFSIZE = $(SIZE) $(MCU_FLAG) $(FORMAT_FLAG) $(TARGET).elf
MCU_FLAG = $(shell $(SIZE) --help | grep -- --mcu > /dev/null && echo --mcu=$(MCU) )
FORMAT_FLAG = $(shell $(SIZE) --help | grep -- --format=.*avr > /dev/null && echo --format=avr )
sizebefore:
	@if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); \
	2>/dev/null; echo; fi
sizeafter:
	@if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); \
checkhooks: build
	@echo
	@echo ------- Unhooked LUFA Events -------
	@$(shell) (grep -s '^Event.*LUFA/.*\\.o' $(TARGET).map | \
	           cut -d' ' -f1 | cut -d'_' -f2- | grep ".*") || \
			   echo "(None)"
	@echo ----- End Unhooked LUFA Events -----
checklibmode:
	@echo
	@echo ----------- Library Mode -----------
	@$(shell) ($(CC) $(ALL_CFLAGS) -E -dM - < /dev/null \
	          | grep 'USB_\(DEVICE\|HOST\)_ONLY' | cut -d' ' -f2 | grep ".*") \
	          || echo "No specific mode (both device and host mode allowable)."
	@echo ------------------------------------
# Display compiler version information.
gccversion :
	@$(CC) --version
# Program the device.
program: $(TARGET).hex $(TARGET).eep
	$(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
flip: $(TARGET).hex
	batchisp -hardware usb -device $(FLIP_PREFIX)$(MCU) -operation erase f
	batchisp -hardware usb -device $(FLIP_PREFIX)$(MCU) -operation loadbuffer $(TARGET).hex program
	batchisp -hardware usb -device $(FLIP_PREFIX)$(MCU) -operation start reset 0
dfu: $(TARGET).hex
	dfu-programmer $(MCU) erase
	dfu-programmer $(MCU) flash --debug 1 $(TARGET).hex
	dfu-programmer $(MCU) reset
flip-ee: $(TARGET).hex $(TARGET).eep
	copy $(TARGET).eep $(TARGET)eep.hex
	batchisp -hardware usb -device $(FLIP_PREFIX)$(MCU) -operation memory EEPROM erase
	batchisp -hardware usb -device $(FLIP_PREFIX)$(MCU) -operation memory EEPROM loadbuffer $(TARGET)eep.hex program
dfu-ee: $(TARGET).hex $(TARGET).eep
	dfu-programmer $(MCU) flash-eeprom --debug 1 --suppress-bootloader-mem $(TARGET).eep
# Generate avr-gdb config/init file which does the following:
#     define the reset signal, load the target file, connect to target, and set
#     a breakpoint at main().
gdb-config:
	@$(REMOVE) $(GDBINIT_FILE)
	@echo define reset >> $(GDBINIT_FILE)
	@echo SIGNAL SIGHUP >> $(GDBINIT_FILE)
	@echo end >> $(GDBINIT_FILE)
	@echo file $(TARGET).elf >> $(GDBINIT_FILE)
	@echo target remote $(DEBUG_HOST):$(DEBUG_PORT)  >> $(GDBINIT_FILE)
ifeq ($(DEBUG_BACKEND),simulavr)
	@echo load  >> $(GDBINIT_FILE)
endif
	@echo break main >> $(GDBINIT_FILE)
debug: gdb-config $(TARGET).elf
ifeq ($(DEBUG_BACKEND), avarice)
	@echo Starting AVaRICE - Press enter when "waiting to connect" message displays.
	@$(WINSHELL) /c start avarice --jtag $(JTAG_DEV) --erase --program --file \
	$(TARGET).elf $(DEBUG_HOST):$(DEBUG_PORT)
	@$(WINSHELL) /c pause
	@$(WINSHELL) /c start simulavr --gdbserver --device $(MCU) --clock-freq \
	$(DEBUG_MFREQ) --port $(DEBUG_PORT)
endif
	@$(WINSHELL) /c start avr-$(DEBUG_UI) --command=$(GDBINIT_FILE)
# Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
COFFCONVERT = $(OBJCOPY) --debugging
COFFCONVERT += --change-section-address .data-0x800000
COFFCONVERT += --change-section-address .bss-0x800000
COFFCONVERT += --change-section-address .noinit-0x800000
COFFCONVERT += --change-section-address .eeprom-0x810000
coff: $(TARGET).elf
	@echo
	@echo $(MSG_COFF) $(TARGET).cof
	$(COFFCONVERT) -O coff-avr $< $(TARGET).cof
extcoff: $(TARGET).elf
	@echo
	@echo $(MSG_EXTENDED_COFF) $(TARGET).cof
	$(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof
# Create final output files (.hex, .eep) from ELF output file.
%.hex: %.elf
	@echo
	@echo $(MSG_FLASH) $@
	$(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
%.eep: %.elf
	@echo
	@echo $(MSG_EEPROM) $@
	-$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
	--change-section-lma .eeprom=0 --no-change-warnings -O $(FORMAT) $< $@ || exit 0
# Create extended listing file from ELF output file.
%.lss: %.elf
	@echo
	@echo $(MSG_EXTENDED_LISTING) $@
	$(OBJDUMP) -h -z -S $< > $@
# Create a symbol table from ELF output file.
%.sym: %.elf
	@echo
	@echo $(MSG_SYMBOL_TABLE) $@
	$(NM) -n $< > $@
# Create library from object files.
.SECONDARY : $(TARGET).a
.PRECIOUS : $(OBJ)
%.a: $(OBJ)
	@echo
	@echo $(MSG_CREATING_LIBRARY) $@
	$(AR) $@ $(OBJ)
# Link: create ELF output file from object files.
.SECONDARY : $(TARGET).elf
.PRECIOUS : $(OBJ)
%.elf: $(OBJ)
	@echo
	@echo $(MSG_LINKING) $@
	$(CC) $(ALL_CFLAGS) $^ --output $@ $(LDFLAGS)
# Compile: create object files from C source files.
$(OBJDIR)/%.o : %.c
	@echo
	@echo $(MSG_COMPILING) $<
	$(CC) -c $(ALL_CFLAGS) $< -o $@
# Compile: create object files from C++ source files.
$(OBJDIR)/%.o : %.cpp
	@echo
	@echo $(MSG_COMPILING_CPP) $<
	$(CC) -c $(ALL_CPPFLAGS) $< -o $@
# Compile: create assembler files from C source files.
%.s : %.c
	$(CC) -S $(ALL_CFLAGS) $< -o $@
# Compile: create assembler files from C++ source files.
%.s : %.cpp
	$(CC) -S $(ALL_CPPFLAGS) $< -o $@
# Assemble: create object files from assembler source files.
$(OBJDIR)/%.o : %.S
	@echo
	@echo $(MSG_ASSEMBLING) $<
	$(CC) -c $(ALL_ASFLAGS) $< -o $@
# Create preprocessed source for use in sending a bug report.
%.i : %.c
	$(CC) -E $(MCU_PARAM) -I. $(CFLAGS) $< -o $@
# Target: clean project.
clean: begin clean_list clean_binary end
clean_binary:
	$(REMOVE) $(TARGET).hex
clean_list:
	@echo $(MSG_CLEANING)
	$(REMOVE) $(TARGET).eep
	$(REMOVE) $(TARGET)eep.hex
	$(REMOVE) $(TARGET).cof
	$(REMOVE) $(TARGET).elf
	$(REMOVE) $(TARGET).map
	$(REMOVE) $(TARGET).sym
	$(REMOVE) $(TARGET).lss
	$(REMOVE) $(SRC:%.c=$(OBJDIR)/%.o)
	$(REMOVE) $(SRC:%.c=$(OBJDIR)/%.lst)
	$(REMOVE) $(SRC:.c=.s)
	$(REMOVE) $(SRC:.c=.d)
	$(REMOVE) $(SRC:.c=.i)
	$(REMOVEDIR) .dep
doxygen:
	@echo Generating Project Documentation...
	@doxygen Doxygen.conf
	@echo Documentation Generation Complete.
clean_doxygen:
	rm -rf Documentation
# Create object files directory
$(shell mkdir $(OBJDIR) 2>/dev/null)
# Include the dependency files.
-include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
# Listing of phony targets.
.PHONY : all checkhooks checklibmode begin  \
finish end sizebefore sizeafter gccversion  \
build elf hex eep lss sym coff extcoff      \
clean clean_list clean_binary program debug \
gdb-config doxygen dfu flip flip-ee dfu-ee
I know the above is long, but I want to be complete. Compiling with the above gives the following output:
avr32-gcc (GCC) 4.2.2-atmel.1.1.2 (mingw32 special) (mingw32 special)
Copyright (C) 2007 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Compiling C: BoardTest.c
avr32-gcc -c -mpart=uc3b0256 -I. -gdwarf-2 -DF_CPU=8000000UL -DF_CLOCK=8000000UL -DBOARD=BOARD_EVK1101 -DUSE_NONSTANDARD_DESCRIPTOR_NAMES -DNO_STREAM_CALLBACKS -DUSB_DEVICE_ONLY -DUSE_STATIC_OPTIONS="(USB_DEVICE_OPT_FULLSPEED | USB_OPT_REG_ENABLED | USB_OPT_AUTO_PLL)" -Os -funsigned-char -funsigned-bitfields -ffunction-sections -fpack-struct -fshort-enums -finline-limit=20 -Wall -Wstrict-prototypes -Wundef -Wa,-adhlns=./BoardTest.lst -I../../ -std=gnu99 -Wundef -MMD -MP -MF .dep/BoardTest.o.d BoardTest.c -o BoardTest.o
Linking: BoardTest.elf
avr32-gcc -mpart=uc3b0256 -I. -gdwarf-2 -DF_CPU=8000000UL -DF_CLOCK=8000000UL -DBOARD=BOARD_EVK1101 -DUSE_NONSTANDARD_DESCRIPTOR_NAMES -DNO_STREAM_CALLBACKS -DUSB_DEVICE_ONLY -DUSE_STATIC_OPTIONS="(USB_DEVICE_OPT_FULLSPEED | USB_OPT_REG_ENABLED | USB_OPT_AUTO_PLL)" -Os -funsigned-char -funsigned-bitfields -ffunction-sections -fpack-struct -fshort-enums -finline-limit=20 -Wall -Wstrict-prototypes -Wundef -Wa,-adhlns=BoardTest.o -I../../ -std=gnu99 -Wundef -MMD -MP -MF .dep/BoardTest.elf.d BoardTest.o --output BoardTest.elf -Wl,-Map=BoardTest.map,--cref -Wl,--relax  -Wl,--gc-sections     -lm
Creating load file for Flash: BoardTest.hex
avr32-objcopy -O ihex -R .eeprom BoardTest.elf BoardTest.hex
Creating load file for EEPROM: BoardTest.eep
avr32-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \
	--change-section-lma .eeprom=0 --no-change-warnings -O ihex BoardTest.elf BoardTest.eep || exit 0
Creating Extended Listing: BoardTest.lss
avr32-objdump -h -z -S BoardTest.elf > BoardTest.lss
Creating Symbol Table: BoardTest.sym
avr32-nm -n BoardTest.elf > BoardTest.sym
(None)
USB_DEVICE_ONLY
Size after:
   text	   data	    bss	    dec	    hex	filename
   2994	   2096	   4160	   9250	   2422	BoardTest.elf
And produces a .elf and a .hex file. However, I can't seem to program this into the EVK1101 correctly, as it gives a warning about the flash overlapping the bootloader area:
batchisp -hardware usb -device at32uc3b0256 -operation erase f
Running batchisp 1.2.4 on Wed Mar 18 21:58:41 2009
AT32UC3B0256 - USB - USB/DFU
Device selection....................... PASS
Hardware selection..................... PASS
Opening port........................... PASS
Reading Bootloader version............. PASS	1.0.2
Erasing................................ PASS
Summary:  Total 5   Passed 5   Failed 0
batchisp -hardware usb -device at32uc3b0256 -operation loadbuffer BoardTest.hex program
Running batchisp 1.2.4 on Wed Mar 18 21:58:45 2009
Parsing HEX file....................... PASS	BoardTest.hex
Programming memory
WARNING: The user program and the bootloader overlap!
Programming memory..................... PASS	0x00000	0x01387
Summary:  Total 6   Passed 6   Failed 0
batchisp -hardware usb -device at32uc3b0256 -operation start reset 0
Running batchisp 1.2.4 on Wed Mar 18 21:58:46 2009
Starting Application................... PASS	RESET	0
Does anyone know where my compile/link/program stage is going wrong? I can't seem to find any reference makefiles which I can compare mine to.
Looking forward to experimenting with AVR32s.
Cheers!
- Dean :twisted:
OK, the UC3 part comes with a preprogrammed USB bootloader.
Here you have 2 choices:
1/ keep the USB bootloader (user guide here: http://www.atmel.com/dyn/resourc...), your application should be linked at 0x80002000, this is the address the bootloader will launch. That is explaining why you have the "WARNING: The user program and the bootloader overlap! " message.
2/ get rid of the USB bootloader (you can reprogram it later with JTAG), just do "avr32program chiperase" (the bootloader is protected with the BOOTPROT fuse). Your application need to be linked at 0x80000000 (reset vector).
If you look at the software framework code, it comes (in the zip version) with standalone makefile (I likethe "make rebuild program reset run" command). By default, the example are compiled with the trampoline section (trampoline.S linked at 0x80000000-0x80002000), which makes the examples to work either with and without the USB bootloader (in all case the "real" application starts in 0x80002000).
-sma
