New in AVR32 world, I am playing with TC modules on an EVK1100 (UC3A0512).
Starting from TV example 3 (using the TC0 to create an interrupt each 100ms), i have done one library to manage time for LEDs.
Now, i started to create a second library with the use of TC1 (used to create a different time base). So i have done quite the same source code (changing only the TC_CHANNEL) and of course changing the IT handling to another functions :
INTC_register_interrupt(&timer_irq, AVR32_TC_IRQ1, AVR32_INTC_INT0);
The result is that my code is not working (It freeze the first timer and in standalone it doen't work (the handling is not done) ).
My question is : Is it possible to create two different handler functions for TC_IRQ0 and TC_IRQ1 ? Is somebody already perform a similar case ?
regards,
PE
