Capacitance or software delay?
2 posts / 0 new
I'm wondering why when I push the botton the light stays on on my output for about .5~.75 seconds before it goes off, is this due to software delay(i.e.) the processor scanning still?
Here is my code:
#include
     DDRB = 0b00000001;   //Sets Port Bit 0 as output
     ADCSRA |= (1 << ADPS2) | (1 << ADPS1);      //ADC Prescalar set to 64 - 125kHz@8MHz
     ADMUX |= (1 << REFS2) | (1 << REFS1);      //Sets ref. voltage to 2.56v internal reference
     ADMUX |= (1 << ADLAR);       // Left adjust ADC result to allow easy 8 bit reading
     ADMUX |= (1 << MUX1);   	//Selects channel ADC2 (PB4) = binary 0010
     ADCSRA |= (1 << ADEN);  // Enable ADC
  while (1) //loop while 1
  ADCSRA |= (1 <<ADSC);	//Starts ADC conversion for single ended mode
  while (ADCSRA & (1 << ADSC) );	//
 if(ADCH < 128)		//If ADCH >  (64x10mv = 1.28v) then Port Bit 0 and 2 are on.
         PORTB |= (1 << 0); // Turn on Port Bit 0
        PORTB &= ~(1 << 0); // Turn off Port Bit 0
//Notes: 2.56v/256 = 10mV resolution in 8-Bit mode
If you don't have a pulldown or pullup resistor on the ADC input, the capacitance will most likely give the results you describe. You could print out the ADC values and you'll see the voltage decay.
