How to make .COF in WinAVR example stdiodemo
C:\WinAVR\doc\avr-libc\examples\stdiodemo
.rar arhive in http://slil.ru/27011869
I’ve read c:\WinAVR\doc\avr-libc\avr-libc-user-manual.pdf
22.36.3 Compiling and Linking page 303 but not fing anything reffer .cof
Text from C:\WinAVR\sample\Makefile
don’t help me too.
Please edit makefile from stdiodemo for .cof output.
PRG = stdiodemo OBJ = stdiodemo.o hd44780.o lcd.o uart.o MCU_TARGET = atmega16 OPTIMIZE = -Os DEFS = LIBS = # You should not have to change anything below here. CC = avr-gcc CFLAGS = -g -Wall $(OPTIMIZE) -mmcu=$(MCU_TARGET) $(DEFS) LDFLAGS = -Wl,-Map,$(PRG).map OBJCOPY = avr-objcopy OBJDUMP = avr-objdump all: $(PRG).elf lst text eeprom $(PRG).elf: $(OBJ) $(CC) $(CFLAGS) $(LDFLAGS) -o $@ $^ $(LIBS) clean: rm -rf *.o $(PRG).elf *.eps *.png *.pdf *.bak rm -rf *.lst *.map $(EXTRA_CLEAN_FILES) lst: $(PRG).lst %.lst: %.elf $(OBJDUMP) -h -S $< > $@ # Rules for building the .text rom images text: hex bin srec hex: $(PRG).hex bin: $(PRG).bin srec: $(PRG).srec %.hex: %.elf $(OBJCOPY) -j .text -j .data -O ihex $< $@ %.srec: %.elf $(OBJCOPY) -j .text -j .data -O srec $< $@ %.bin: %.elf $(OBJCOPY) -j .text -j .data -O binary $< $@ # Rules for building the .eeprom rom images eeprom: ehex ebin esrec ehex: $(PRG)_eeprom.hex ebin: $(PRG)_eeprom.bin esrec: $(PRG)_eeprom.srec %_eeprom.hex: %.elf $(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O ihex $< $@ %_eeprom.srec: %.elf $(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O srec $< $@ %_eeprom.bin: %.elf $(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O binary $< $@ # Every thing below here is used by avr-libc's build system and can be ignored # by the casual user. JPEGFILES = stdiodemo-setup.jpg JPEG2PNM = jpegtopnm PNM2EPS = pnmtops JPEGRESOLUTION = 180 EXTRA_CLEAN_FILES = *.hex *.bin *.srec *.eps dox: ${JPEGFILES:.jpg=.eps} %.eps: %.jpg $(JPEG2PNM) $< |\ $(PNM2EPS) -noturn -dpi $(JPEGRESOLUTION) -equalpixels \ > $@
