how to sync a TC clked by PWM with a TC clked by PBA?
5 posts / 0 new
hi,
I want to build up a 32bit hardware timer, so I let TC2 by clocked by PWM2 with frequency of PBA/2/65536, and TC0 by clocked by PBA/2.
But now I don't know if there is way to sync PWM output to PBA clocks.
I checked the peripheral clock masking, but if the TC or PWM's input clocked are masked, then it's not possible to enable their counters.
Anyone knows the way???
it seems it could work if i use the BURST function to block the PBA clock of low 16bit time and then it could be in sync.
just measured the result, and it got a delay of one PBA clk between the low 16bit timer output waveform and high 16bit timer input PWM clk.
I think this problem comes from the mismatch of PBA/2 clock source for driving TC and another PBA/2 for PWM.
but i can't find a fix....
have you seen the TC erratum on some revisions on the Timer input clock? (there is sometimes a /2 ratio)
-sma
yes, but my UC3B is not engineering sample.
So there shouldn't be error in TC, right?
