UC3 flashc linker script problem
4 posts / 0 new
I am getting the error:
/usr/avr32/bin/ld: bug_test.elf: section `.ctors' can't be allocated in segment 0
/usr/avr32/bin/ld: final link failed: Bad value
collect2: ld returned 1 exit status
after trying to use the linker file that comes with AVR32749 (the flashc bug workaround for AT32UC3Ax512 Revision E, H and I) Has anyone run into this problem before?
The command I run is:
avr32-gcc -march=ucr2 -mpart=uc3a0512 -Wl,--gc sections -Wl,-e,_trampoline -T link_uc3a0512.lds -ffunction-sections -fdata-sections -fno-strict-aliasing  -o bug_test.elf  bug_test.o config.o  trampoline.o -L../../common/lib  -lfreertos -lintc -lnlao -lshell -lutil -lusart  -lm -lgpio -ltc -lbsp -lpm -lflashc -ltree
I have the same problem. I have updated the studio to version 2.1.0, framework version 1.4.0, toolchain version 2.1.4 (don't know what version it was before). Now i tried to compile my older projects with the new studio version (the workaround for flash update worked with the older studio). I had to change some sources (framework compatibility) until i ran into same problem as the threadstarter. Any ideas what the problem could be?
You need to update the linker file to the latest linkers from the software framework 1.4.0 (UTILS/LINKER_SCRIPT).
Changes have been made in avr32-ld so the old linker script gives this error.
-sma
Thank you sma,
i modified the linker script from the new toolchain. Now the linker links without a error. In the map file i can see that the 0 pages are reserved. I append the linker script file for the workaround.
