Hi.
I am trying to get a c++ debug example running on my AT91SAM7S256.
I have downloaded the example at91sam7s_cpp from
http://www.siwawi.arubi.uni-kl.d...
I am trying to run this in Eclispe using openocd and ARM-USB-OCD.
I have already sucessfully run a C program from Eclipse in debug, but
want to get a C++ example running as I intend to write my app using OO and C++.
My questions are:
1) When running the C program from Eclipse the Compiler invocation
command is set to C:\gccfd\yagarto\bin\arm-elf-gcc.exe, shuold I change
this for C++? to arm-elf-g++.exe? or something else
2) For the debugger options I have C:\gccfd\yagarto\bin\arm-elf-gdb.exe,
is that correct for C++?
3) The make file which came with the example compiles for ROM (final)
and not RAM (debug), I have changed this throughout and the project
builds without error, but when I try to debug I get the error No source
available for "main() " - View Disassembly
I have attached a copy of the modified make file.
I feel Im almost there - but not quite (or may not!)
Anyway, time to ask for some advise, so any help would be greatly
appreciated.
Sam.
