[ASM] Mega644 && Timer2 = StackOverflow?!
8 posts / 0 new
Hey Freaks,
I've read abc's, Timers ROCK and some of the 644's Datasheet.
My final aim is to produce a bunch of independant PWM's ... say 20. To get a start I tried to translate miniusers CTC stuff into ASM. It didn't work so "hey let's start with counting again" I read through the datasheet and configured every T2 reg as I pleased. I came up with this:
Setup:
- AVR Studio 4.13
- Assembler
- AVR Simulator
- ATMega644
current aim:
- run Timer2 in normal mode, no prescale, preload 0x55
Problem is: if I click on "run" or "auto step" I get the messages
AVR Simulator: Unititializes Stackpointer used at 0x003B
invalid opcode 0x00B2 at adress 0x00002A
stack overflow at 0x003B (repeats endlessly)
and the PC jumps from
rjmp main
to
;[OCR2A]	OutputCompare Register
	clr w
If I comment out "sei" it doesn't appear and jumps properly. But TCNT2 isn't increasing.
Is the overflow a problem of AVRsim or is it my fault? Is there anything wrong with my timer config?
Here's my complete code:
; 					     Processor specific stuff
.device ATmega644
.include "m644def.inc"
;						 	work registers
;[work registers]
.def   	u		=	r16
.def	w		=	r17
;						     Vector Table
.cseg
.org   	$0000	RJMP reset
.org	$0016	RJMP TIM2_OVF
RETI
reset:
	RJMP init
;							Initialization
init:
;[INIT STACK]
	ldi w, high(RAMEND)
	sts SPH, w
	ldi w, low(RAMEND)
	sts SPL, w
;[INIT PORTD]
	ser w
	out DDRD, w				;all PORTD Pins are output
	clr w
	out PORTD, w			;all PORTD Pins are High
;[INIT TIMER 2]
	;[TCCR2A] 0 0 0 0 0 0 0 0 TimerCounterControll Register
	clr w
	sts TCCR2A, w
	;[TCCR2B] 0 0 0 0 0 0 0 0 no prescale
	sts TCCR2B, w
	;[TCNT2]	Timer/Counter Register
	ldi w, 0x55
	sts TCNT2, w
	clr w
	sts OCR2A, w
	;[OCR2B]
	sts OCR2B, w
	;[ASSR] 	Asynchronus Status Register
	sts ASSR, w
	;[TIMSK2]	Interrupt on Overflow
	ldi w, 0x01
	sts TIMSK2, w
	;[TIFR2]	TimerInterruptFlag Register
	clr w
	sts TIFR2, w
	;[GTCCR]	GeneralTimer/Counter Controll Register
	sts GTCCR, w
sei
jmp main
;							        MAIN
main:
rjmp main
;							     Interrupts
TIM2_OVF:
	inc w
	out PORTD, w
reti
.device ATmega644
Not needed. By the way are you using M644 or M644P?
RETI
What's that RETI doing there?
 RJMP init
;                     Initialization
init:
Not really needed, just rename init: to reset:
All rjmp should be jmp in the vectors. Somehow you are triggering INT0 etc. (code jumps to 0x0002 which is 0xffff) so do a bit more init in your code.
DO NOT TRUST THE SIMULATOR. :?
edit simulator2 behaves a little better but the INT0 problem is still there.
;[INIT STACK]
   ldi w, high(RAMEND)
   sts SPH, w
   ldi w, low(RAMEND)
   sts SPL, w
What makes you think you can use STS with the stack pointer anyway? :) Have a good look at the rest of your init also.
I orderd ATMega644-20PU-ND. That's M644, isn't it?
The RETI was supposed to handle unexpected interrupts. Better: I'll write down the complete vector table and do jumps to some kind of error ISR.
I ususally used OUT instead of STS. Since OUT doesn't work with some config registers of the M644 I figured I'd use STS for all.
Ok, next step will be a complete Init for all config regs ... good thing is that it only needs to be once. Plus it's a reason to start with multiple file assembly ^^
Thanks for your help, John :)
Try using the macros in AVR001: Conditional Assembly and portability macros:
http://www.atmel.com/dyn/resourc...
The LOAD and STORE macros will keep you from ever making that type of sts vs. out mistake ever again.
Yes but it is NOT the same as the Mega644p, just in case you wonder in the future. :)
Apart from using the macros as suggested above you CAN use sts >> IF << you offset the address by 0x20 as shown in the datasheet (addresses in parenthesis). The address for ports in the 0x00 - 0x3f range will be defined for the OUT instruction otherwise.
That macro stuff is very helpfull :)
I've had chosen the wrong mega at the simulater menue. After making a new project and fixing a init error TCNT2 is running. The IRQ bug is gone as well.
Go and buy yourself a drink!! :)
