Problem with _delay_ms function
11 posts / 0 new
Hello Guys,
i am executing the following code on my Atmega8515 board. The crystal is of 8MHz.LED is connected to the output pint of PORT A. The problem is i am not getting one second delay between ON and OFF. The delay seems to be around 8 Seconds. :cry:
#include  // avr header file for IO ports
#include
	unsigned char i; // temporary variable
	DDRA = 0x00; // set PORTA for input
	PORTA = 0x00; // turn ON all LEDs initially
		PORTA = 0x01;
		_delay_ms(1000);
		PORTB = 0x00;
		_delay_ms(1000);
	return 1;
My final aim is to drive two servo connect to PinA.1 and PinA.2 for which i will change the timings in range of (1 - 2 ms). Can anyone suggest any other method for driving servos.
I guess timer can be used but i am not sure how.
Regards
Nitin D
check the CLK div 8 fuse in the fuses.
sounds typically like it is set, so the processor is running 8 times slower then you think it is.
regards
In WinAVR delay() has terrafic restrictions !!! Read
WinAVR-folder\doc\avr-libc\avr-libc-user-manual.pdf
6.28 : Basic busy-wait delay loops
page 166
and be cool ! :lol:
CVAVR delay is real nice one.
Timer yes ! See 8 servo control by one timer
http://avr123.nm.ru/z13.htm - google will translate it for you. Source code need not translations.
Are you using an old version by any chance? For more than a year most of the previous restrictions of _delay_ms() and _delay_us() have been removed.
Cliff
PS I'll move this to GCC...
While the restrictions remain in the documentation. I just double checked the on-line version, and my locally installed (WinAVR-20081205), and they both still specify the 262.14/F_CPU [ms/MHz].
but then have an additional paragraph that the older docs didn't have about coarser granularity abovete threshold. But I agree it is a bit misleading.
Oh dear.. That was really sloppy reading of me. I just glansed over
The maximal possible delay is 262.14 ms / F_CPU in MHz.
and didn't read more as I thought that was conclusive.
Sorry..
Sorry..
It looks conclusive to me.
Starting with WinAVR 20081205, there are some new built in functions including this one:
void __builtin_avr_delay_cycles(unsigned long __n);
Hey guys
Thanks for all your replies. The problem was with the fuse settings.
Regards
Nitin
