returing a value from a routine
4 posts / 0 new
I have a routine I use to read different ADCs. Right now I'm storeing the result in a variable and using the variable afterwards in the Main section.
uint16_t adcval = 0;
uint16_t adc1 = 0;
uint16_t adc2 = 0;
void readADC(uint8_t newadmux)
  ADMUX = newadmux;
  // read ADC several times
  // adding the values of each read.
  adcval = [summed and averaged ADC values];
main()
  readADC(0x03);
  adc1 = adcval;
  readADC(0x82);
  adc2 = adcval;
  // remainder of code
Is there a better way to return the result of the readADC() routine?
Also, do I need to declare the adc1 and adc2 variables as globals or should it more properly be done in the main() section like below.
 uint16_t adc1 = adcval;
Thanks for your help. I'm rubbish when it comes to C.
Jim M., Rank amateur AVR guy.
grab yourself a copy of K&R's C programming.
See the tutorials here by Smiley and in the last few issues of "Nuts 'n Volts" magazine
Consider this
uint16_t readADC(uint8_t newadmux)
  uint16_t ret;
  ADMUX = newadmux;
  ret = [summed and averaged ADC values];
  return(ret);
void main(void)  {
  uint16_t adc;
  adc = readADC(3);
  // more code
Declare them where it is convenient for you.
Steve A.
Thanks, both.
I'll have a look at those references.
