Can ATMEGA16 read negative voltage on ADC?
10 posts / 0 new
I was wondering if anyone knows how to read a negative input voltage on any of the ADC pins of the atmega16. Ideally, I would like to do this with only using a positive (7805) power supply. Any ideas would be appreciated.
thanks,
Andy
If you want to read +-10v for example, you need to attenuate by 1/4th to get the 20v range down to 5v, then you must add 2.5v to bias the signal in the middle of the 0-5v range. Some smart person can draw us a picture of the circuit to do this.
You might get away with just 2 resitors....
Connect them in series & the common between them goes to the a/d.
Call the top resistor T going to the high positive voltage H.
The bottom resistor B goes to the low voltage L.
The voltage going to the a/d will be:
(HB + LT)/(T+B)
L is your negative voltage (so it really ends up subtracting). H is probably your +5 V supply.
For even better performance, use a level shifting opamp circuit.
Hoyt
so for Bob's example if H=5 volts and B=1000 ohms
If T=500 ohms then
L=0 volts GIVES 3.333 V AT A/D
L=-10 volts GIVES 0.00 V AT A/D
If T=400 ohms
L=0 volts GIVES 3.57 V AT A/D
L=-10 volts GIVES 0.714 V AT A/D
etc etc etc
Excel is your friend
Hoyt
If T=500 ohms then
If T=400 ohms
etc etc etc
Hoyt
This is the usual way to do it:
           Vcc
           2R
bipolar--R--
            |--- unipolar
           2R
          Gnd
Leon
Leon Heller G1HSM
Leon,
Given the circuit diagram shown, is "bipolar" supposed to be the voltage input? Is "unipolar" supposed to be the voltage into the adc?
thanks,
Andy
Yes.
Leon
Leon Heller G1HSM
           Vcc
           2R
bipolar--R--
            |--- unipolar
           2R
          Gnd
Leon
I was try to simulate this and correct values of resistors is here:
            Vcc
             R
bipolar--2R--|
             |--- unipolar
            2R
           Gnd
Computers don't make errors - What they do they do on purpose.
Thanks for your help. I did notice the error in resistor placement. Using 5k as R, I get -10 to +10 inputs to produce adc inputs of 0 to 5 volts. This is exactly what I wanted. Thanks again.
Andy
