Hi
i want ot interface an avr to ethernet, exactly i want to read for example lm35 temp, and then put it on ethernet how can i do it???
avr AND enc28j60
Google would've found you this:
Given the LM35 is a 4 volt minimum supply device and the ENC28J60 is a 3.6 volt maximum device, would suggest you are using a 5 volt Vcc for the AVR and a 3.3 volt Vcc for the ENC28J60. This schematic has the 5 volt to 3.3 volt Vcc level translation circuits:
You might want to look at the LM50 instead of the LM35. Using the AVR ADC 2.56 v reference you should be able to divide the result by 4 (a simple shift operation) and subtract 50 decimal to get the direct Celsius value in 1/4 degree steps. Adding back 1/4 to fractional part of the result should correct for round off. I have not tried it yet, but is looks like it should work.
There is a wiznet ethernet chip, it's communicate with AVR by SPI and has the stacks for the ethernet comunication..
There are other chips similar than this one.. Microchip has too..
The Kartman's link is really helpfull..
Brunomusw
Thank you my friends i'm gonna do it then if i had any problem , i'll say it here and hope you help me.
