Overhead associated with Reading from Program Memory
6 posts / 0 new
Is there a difference in overhead reading from RAM vs. reading from program memory?
Andy
You may need to use a search function it work very well or read this tutorial.
I am very familiar with that tutorial, and have refered to it many times. I have experience with PROGMEM, but just never in time sensitive situations. That tutorial does not address my question.
Avr Instruction Set datasheet lists cycles for each instruction.
ldi r31,0 //1cycle
ldi r30,0 //1cycle
lpm r24,Z //3cycles
lds r24,0x0100 /2cycles
so reading flash will be at the very least least 1 cycle slower per byte.
You need to refer to the AVR instruction set (not just the summary that is included in every AVR data sheet, but the long version).
This is what I understand from that document:
Each read takes 3 clock cycles as opposed to the 2 clock cycles while reading from SRAM.
The other overhead - managing the pointer registers - is the same.
Drat! curtvm beat me to it. :D
If you think education is expensive, try ignorance.
Often more because of the need to set up the index register. Consider this:
	DDRB = x;
  94:	80 91 60 00 	lds	r24, 0x0060
  98:	87 bb       	out	0x17, r24	; 23
	DDRC = pgm_read_byte(&y);
  9a:	e4 e5       	ldi	r30, 0x54	; 84
  9c:	f0 e0       	ldi	r31, 0x00	; 0
  9e:	e4 91       	lpm	r30, Z+
  a0:	e4 bb       	out	0x14, r30	; 20
