Max freq of PWM from AVR with 8 bits res? - FPGA inside AVR?
12 posts / 0 new
Hello :-)
Can someone point me to the maximum frequency of PWM with 8 bits resolution I can have? -- I did read the datasheet of ATxmega and discovered that is just get 125kHz (32MHz / 256).
I worked with ATtiny861 that gets 250kHz, a special PLL for PWM at 64MHz, 64MHz / 256 = 256kHz.
Alternatives
Anyone knows if Atmel will get something like PSoC from Cypress?
... complete solution for embedded systems, combining an 8-bit microcontroller, flash memory, and SRAM with customizable analog and digital blocks.
Or maybe should I think in a kind of FPGA (don't understand nothing about it) to make a faster external PWM module?
Thank you.
JPCasainho,
www.Casainho.net
.Portugal
Atmel combines a FPGA and an AVR in what they call FPSLIC: http://www.atmel.com/products/fp... .
Okok!! thanks, I will investigate that product from Atmel ;-)
And I couldn't find any AVR with higher frequency (at 8 bits res) than the ATtiny861, 250kHz.
JPCasainho,
www.Casainho.net
.Portugal
Leon Heller G1HSM
I believe that limit on PWM speed is correct. You are up against fundamental limits of clock speed. PWR repetition frequency is Fclock/2**N, where N is the number of resolution bits and Fclock is the PWM counter clock rate.
leon_heller wrote:
XMOS: http://www.xmos.com
Eheh - a bit too much for our needs ;-)
I enjoyed the mention to Open Source tools, some of them I know about and use :-)
JPCasainho,
www.Casainho.net
.Portugal
When we get up into 100kHz+ speeds, it always begs the question: "Why would this be needed in general-purpose work?"
OK, let's say that OP comes back with a compelling reason. [I'm waiting with bated breath.] While waiting, let's examine
Xmegas are too bullet-riddled for common people to use, but it would sure seem that clkPER4 would be at 4x32MHz=128MHz and thus allow a 500kHz frequency.
Lee
Since I understand, Timer to use for PWM just can have clock of max speed of CPU, so, the 32MHz.
And I am looking for that higher frequency for DC-DC circuits, to try lower the values of capacitors and inductors... we are using now the ATtiny861 with PWM of 250kHz.
JPCasainho,
www.Casainho.net
.Portugal
Yes but PWM then splits this. If it's 8 bit PWM then it chops the frame into 256 steps so 8bit PWM on 32MHz might offer 32M/256 = 125KHz
Cliff
See "17. Hi-Res - High Resolution Extension". It would appear to me that since it runs off clkPER4 that it would indeed give the capability, but not having used Xmega in anger I cannot verify that.
Hmmm... maybe, if it can have higher resolution, then we can lower it to 8 bits again and have higher frequency.
Yes, that's true.
JPCasainho,
www.Casainho.net
.Portugal
Attiny26 also have a 64Mhz PLL for timer1 :idea:
