FAILed to conect PC <=> DT-AVR low cost micro system
6 posts / 0 new
yesterday i bought DT-AVR low cost micro system from innovative electronic.com,
but when i start testing n using TESTBOARD.EXE (a program from inovative electronic to test DT-AVR low cost micro system) its always show "FAIL!!"
i have conect my DT-AVR low cost micro system with 9v VDC..
i dont know what wrong??
someone help me please...
thanks.
How do you attempt to load the program? How do you connect it to your computer?
Are you using their optional in-system programmer?
I use rj11 to connect from modul n use db9 to connect to my pc,
The program is built in from vendor.
I using windows xp as my os. I use default setting
I would contact the vendor.
The documentation is not extensive, the board contains a mega8535, power regulator, a simple RS232 level converter, RS232 brought to a RJ11 plug and the ports brought to pin-headers.
Assuming the shipped 8535 contains a boot-loader or some test code then you need the J4/J5 jumpers correctly set to wire the RX/TX pins to the serial port and a correctly wires serial cable.
- Are the serial jumpers (J4/J5) set on the 1-2 pins ?
- Are you using a good cable (did it come with the kit) ?
- Are you using the correct serial port on your PC ?
Markus
Markus
thanks to markus_b and ka7ehk,,,
now i think to complain at vendor because all markus sugest i have done n still failed in test..
thanks to you all...
