LCD display
10 posts / 0 new
i'm having trouble with the display:
i'm using KS0066U dased lcd(PC1602F from POWERTIP company)
my code:
main.h
#ifndef MAIN_H
#define MAIN_H
#include
#include
#include
#define LCD_DATA_PORT PORTD
#define LCD_DATA_DDR DDRD
//define lcd control port
#define LCD_CTRL_PORT PORTB
#define LCD_CTRL_DDR DDRB
#define LCD_rs 0
#define LCD_rw 1
#define LCD_en 2
// LCD instructions
#define LCD_origin() LCD_command(0x2)	/* Set to origin LCD */
#define LCD_function_set() LCD_command(0x28) /* LCD function set */
#define LCD_display_off() LCD_command(0x08) /* LCD display off*/
#define LCD_display_on() LCD_command(0x0F) /* LCD display on*/
#define LCD_display_clear() LCD_command(0x01)/* Clear display LCD */
#define LCD_mode_set() LCD_command(0x06) /* LCD mode set */
//functions declarations
void LCD_enable();
void LCD_command(unsigned char command);
void LCD_putc(unsigned char ascii);
void LCD_puts(unsigned char *lcd_string);
void LCD_init();
#endif
main.c
#include "main.h"
unsigned char *ptr = "AVR Project";
int main()
	LCD_init();
	LCD_puts(ptr);
void LCD_enable()
    LCD_CTRL_PORT &= ~(1<<LCD_en);
    _delay_ms(1);
    LCD_CTRL_PORT |= (1<<LCD_en);
    LCD_CTRL_PORT &= ~(1<<LCD_rs);
    LCD_DATA_PORT = (command & 0xF0)|(LCD_DATA_PORT & 0x0F);
    LCD_enable();
    LCD_DATA_PORT = (command << 4 & 0xF0)|(LCD_DATA_PORT & 0x0F);
    LCD_enable();
    _delay_ms(1);
    LCD_CTRL_PORT |= (1<<LCD_rs);
    LCD_DATA_PORT = (ascii & 0xF0)|(LCD_DATA_PORT & 0x0F);
    LCD_enable();
    LCD_DATA_PORT = (ascii << 4 & 0xF0)|(LCD_DATA_PORT & 0x0F);
    LCD_enable();
    _delay_ms(1);
	while (*lcd_string)
		LCD_putc(*lcd_string++);
void LCD_init()
   //initialize LCD control lines
   LCD_CTRL_PORT &= ~(1<<LCD_rs);	// RS low
   LCD_CTRL_PORT &= ~(1<<LCD_rw);	// R/W low
   LCD_CTRL_PORT &= ~(1<<LCD_en);	// E low
   // initialize LCD control lines to output
   LCD_CTRL_DDR |= (1<<LCD_rs);
   LCD_CTRL_DDR |= (1<<LCD_rw);
   LCD_CTRL_DDR |= (1<<LCD_en);
   // initialize LCD data port to input
   	LCD_DATA_DDR |= 0xF0;// Data on high four bits of port
	_delay_ms(30);
	LCD_function_set();
	LCD_function_set();
    _delay_us(40);
	LCD_display_off();
	_delay_us(40);
	LCD_display_clear();
	_delay_ms(2);
	LCD_mode_set();
	LCD_display_on();
i'm using it in 4-bit mode, when i apply power it only shows that the power is available but nothing is displayed.
i'll appreciate any help, from circuit connections to software
regards
Your enable routine is backwards. You should be sending it high, then low.
In looking at the datasheet for the KS0066U, the beginning of the initialization in 4 bit mode looks a little different than the typical HD44780 clone. Try sending a single 4 bit value of 3, then the full function set.
Steve A.
Things could not work out.
my hardware configurations:
LCD------------MCU(ATmega8)
Vss-------------------------->POWER SUPPLY(GND)
Vdd-------------------------->POWER SUPPLY(+5v)
Vo(Contrast Adjust)---------->(120 ohm to GND)
DB7-------------PD7
DB6-------------PD6
DB5-------------PD5
DB4-------------PD4
(DB3-DB0) not connected
(PIN 15 & 16 ) not connected
any help!
Have you tied the unused data lines to ground?
Nigel Batten
www.batsocks.co.uk
yes, DB3 - DB0 are all tied to GND!
I think that koschi's correct.
a) It looks like the enable routine is inversed
b) look at the init routines.
According to the KS0066U doc I've got open, the 4-bit initialise routine should be:
wait 30ms
send 0x2(0) (toggle e)
send 0x8(0) (toggle e)
wait
[other codes]
Your initialise routine appears to just do:
wait 30ms
wait
[other codes]
[edit: corrected summary of your current init routine]
Nigel Batten
www.batsocks.co.uk
this can't work either
void LCD_init()
   _delay_ms(30);
   LCD_command(0x20);
   LCD_command(0x28); //function sset
    _delay_us(40);
   LCD_command(0x08); //display off
   _delay_us(40);
   LCD_command(0x01); //clear diaplay
   _delay_ms(2);
   LCD_command(0x06);//entry mode
   LCD_command(0x0F);// display on
what else might be wrong.
do unconnected LED backlight power suply pins on LCD has effect. if yes, how do i connect them.
any other help will be appreciated
Your initialise routine now does:
wait 30ms
send 0x0(0) (toggle e)
wait
[other codes]
I think it needs to do:
wait 30ms
wait
[other codes]
You can't simply use the existing LCD_command routine, since it always sends a pair of commands and you need to send three.
Nigel Batten
www.batsocks.co.uk
wait 30ms
wait
[other codes]
wait 30ms
wait
[other codes]
thanks for clarifying that! it works now!
i have this!
void LCD_nibble(unsigned char nibble){
    LCD_DATA_PORT = (nibble & 0xF0)|(LCD_DATA_PORT & 0x0F);
    LCD_enable();
void LCD_init()
    _delay_ms(15);
    LCD_nibble(0x30);
    _delay_ms(5);
    LCD_nibble(0x30);
    _delay_ms(1);
    LCD_nibble(0x30);
    _delay_ms(1);
    LCD_nibble(0x20);		//switch to 4 bit mode
   LCD_function_set();
    _delay_us(40);
   LCD_display_off();
   _delay_us(40);
   _delay_ms(2);
   LCD_entry_mode_set();
   LCD_display_on();
Thanks, this code works like magic.
Modified the code slightly
compiles if changed to
And I used PORTD on account of using external 16Mhz clock (have to adjust delay). :D
==edit==
Will also play with setting+controlling the cursor-mode this weekend and paste up my changes if anyone is interrested instead of having to do scrolling manually.
Conrad Braam - www.softcircuitry.blogspot.com - www.plcsimulator.org
Always start off poorly, that way when you finally figure it out, you can get a few surprise hits in.
