printf (& other stdio functions) & dual UARTS
31 posts / 0 new
Hi All,
I have used various stdio functions on an ATMega128,
but now I have a need to send data to both UART 0 & 1.
At this time I close on stream & then open the other
and then back again.
How does one go about calling stdio functions on both streams without closing & opening streams?
Lee
Lee -.-
You can associate as many streams as you want with your respective
backend functions. You just have to use the "f" functions then
(i.e. those starting with the letter "f"). Remember that printf(...)
is just a shorthand for fprintf(stdout, ...).
Jörg Wunsch
OR..
#define com1_in (__iob[3])
#define com1_out (__iob[4])
then
	FILE com1_str = FDEV_SETUP_STREAM(usart1_putchar, usart1_getchar, _FDEV_SETUP_RW);
and
	com1_out = com1_in = &com1_str;
finally something like
	fprintf ( com1_out, "%c%c%c\r", VMUSIC2_set_volume_cmd1,
				VMUSIC2_set_volume_cmd2, (dB * 2));
or
	putc ('\r', com1_out);
...it's good to be a C guru.. :lol:
How to mysteriously crash your embedded application, part #42:
John, these things start with two underscores for a reason: unless
documentation tells you to do so, you are /not/ supposed to ever use
anything like this. Never. In this case: __iob[] has just three
elements, and it is only supposed to hold the handles for stdin,
stdout, and stderr, respectively.
The remainder of your posting is OK.
Btw., there's no reason to have separate handles for input and
output direction. (You don't really have them but make your code
look like they were needed.)
Jörg Wunsch
I'm intregued by this method of talking to the UARTs. Is there some full demo code somewhere?
You mean like in \doc\avr-libc\examples\stdiodemo?
Alternative navigation path is the avr-libc documentation, Example Projects, comprehensive example on using the standard IO facilities.
When everything else fails, read the documentation...
So does that make me a goo instead of a guru?? :lol:
Without the defines I get so many errors and I use the defines without problems. I just looked at the way stdio does it and added 2 more iob thingoes...
So what is the correct way of doing multiple USARTs, 2 or even 4 for chips that have them.
I was so proud of getting the second USART working, almost effortlessly, without asking anyone...I'm SOOOO shattered now.
output direction.
I followed what the examples shows for USART0 in stdiodemo.c.
Can we please have another demo with mutiple USARTs added to the examples? (I may have to switch to a chip with 4 USARTs for a project and I'm sure everyone would want to hold me fast to the dark side)
[Given a recent thread on the Off-Topic forum, perhaps a 'Roo rather than guru.]
A goo-roo then :?
CVAVR has another approach in their demo, not as elegant as the way I did did though. :wink:
// Define the new putchar function
void putchar(char c)
switch (poutput)
       case USART0: // the output will be directed to USART0
            while ((UCSR0A & DATA_REGISTER_EMPTY)==0);
            UDR0=c;
       break;
       case USART1: // the output will be directed to USART1
            while ((UCSR1A & DATA_REGISTER_EMPTY)==0);
            UDR1=c;
       break;
       case LCD:    // the output will be directed to the LCD
            lcd_putchar(c);
   // printf output will be directed to the LCD
   poutput=LCD;
   printf("The LCD has %u\ncharacters/line.",LCD_CHARS_LINE);
   // putsf output will be directed to USART0
   poutput=USART0;
   putsf("The LCD is not present.\r");
// printf output will be directed to USART1
poutput=USART1;
printf("This is a test of USART%u.\r",1);
I can't even see an example with Imagecraft.
To date, I've always done my CV dual-U(S)ART apps with twin drivers. The devices always seem to be dissimilar so I needed some tailoring anyway.
I guess one wants to decide, in a MICROcontroller program, how many simultaneous "files" will be used. The example from CV above would tend to break down with buffered interrupt-driven communications.
My next app, tho, will be a centipede with 4x similar USART streams, so a "generic" driver is in the works. As these are RS485 links, I hat to use the indirect access for the TE-/RE signal, as it is so inefficient but I may have no choice. I also hate to call functions via pointer in ISRs so it is TBD how to write the interrupt handlers. Hmmm--I use different buffer sizes for different needs. Maybe this will be my first AVR malloc() use as well.
Lee
Accessing them trashes 4 bytes or RAM after the variable __iob[] (which is
statically allocated as an array of 3 pointers).
If you've got errors, then don't hesitate to post them. It is supposed to
work without touching __iob[]. The latter is really only there in order to
internally hold the handles for stdin, stdout, and stderr, respectively,
because they are required by the standard, and because stdin and stdout are
used implicitly in some of the functions.
Jörg Wunsch
It is supposed to
I'm posting from another computer and it's late here.
How do I then define com1_in and com1_out for
or don't I need that line? IIRC I get undefined errors which is correct as they are not defined anywhere without the
In other word how do I assign a stream to com1?
Tomorrow I'll compile it againg and see what knid of errors I get.
No need to make the extra alias, you have your stream (FILE) in com1_str so you just need to provide the address when using the stdio functions (that take a FILE*) like so:
fprintf(&com1_str, "%c%c%c\r", MUSIC2_set_volume_cmd1,
/Lars
Ok, maybe you prefer the indirection, then just add your own com1 definition:
FILE *com1 = &com1_str;
/Lars
In the latter case, it will occupy another 2 bytes though. If
it's only your aesthetical feelings that are hurt by the & operator,
try:
#define com1 (&com1_str)
  fprintf(com1, "Hello, beautiful com%d world!\n", 1);
Jörg Wunsch
OK thanks, so don't have to specify com1_in and com1_out. I'll try this out.
Or for those that dislike macros:
static FILE * const com1 = &com1_str;
However:
does use more than 2 extra bytes, there is the code needed the read the pointer as well.
Confusion reign supreme here!! :(
Ok so this is what's happening. All the USART stuff is in the init files (C and H) as follows.
//Ad station mk2 initialization header file
void Ad_station_mk2_init (void);
//#define com1_in (__iob[3])	//Original worked
//#define com1_out (__iob[4])	//Original worked
#define com1 (__iob[3])		//Works
//#define com1 (&com1_str) 	//Doesn't work as com1_str in not known here yet
and in the C init file
	FILE uart_str = FDEV_SETUP_STREAM (usart0_putchar, usart0_getchar, _FDEV_SETUP_RW);
#if debug==0
	MCUCR = (1<<JTD); 							//Disable JTAG in run mode
	MCUCR = (1<<JTD);
#else
	MCUSR_status = MCUSR;						//Make a copy of MCUSR for debugging
#endif
	stdout = stdin = &uart_str;
	com1 = &com1_str;
I have changed all statements that contained com1_out to com1 and it's all working. ie
void VMUSIC2_list_file (char * file_name)
	fprintf ( com1, "%c%c%s\r", VMUSIC2_list_file_cmd1,
				VMUSIC2_list_file_cmd2, file_name);
void VMUSIC2_list_all_files (void)
	putc (VMUSIC2_list_file_cmd1, com1);
	putc ('\r', com1);
I don't have any input from com1 yet with stdio as I'm doing by just reading the UDR, I will need to eventually use stdio for input from com1 as I neeed to read a lot of data using interrupts, so I will use usart1_getchar from the USART1 driver.
Com1 is used in files outside the init file just in case anyone wonders.
I guess the op is no longer interested but now I am.. :?
Actually it need not be known until it is used so I expect the error you got was at the place com1 was used.
You need to make com1_str known by declaring it in the .h file:
extern FILE com1_str;
More here:
https://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=48535
/Lars
Code:
../Ad_station_mk2_init.h:12: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'com1_str'
with or without the semicolon. :(
I even tried the same thing in a few other files.
I guess the most important question is, why does it work the way I did it originally, if is it so wrong.
How about all you clever people post a simple program that prints to 2 (or even 4) different ports using stdio and with separate init files? It's much simpler than trying to guess what's going on. I'm simply using the standard UART.C and H files modified to run with USART and I'm posting them here.
So one file for main and another for USART init.
And just to make it a bit easier for everyone, here is the project to use the 2 com ports with the incorrect, but working, __iob thingoes. Please fix so it would be correct. :-)
//	com_ports_test_init header file
#include
extern FILE com0_str;
#define com0 (&com0_str)
void com_ports_test_init (void);
While I must say I would probably have put the above com0 and com0_str in usart0.h and the com1 and com1_str in usart1.h, instead of having them in yet another .c/.h file combo.
//INIT file
#include
//#include
#include "com_ports_test_init.h"
#include "usart0.h"
#include "usart1.h"
FILE com0_str = FDEV_SETUP_STREAM(usart0_putchar, usart0_getchar, _FDEV_SETUP_RW);
	stdout = stdin = com0;
	usart0_init();
	usart1_init();
Also here, I would have put "FILE com0_str = ..." in usart0.c and "FILE com1_str =" in usart1.c, instead of defining them in com_ports_test_init.c
Thanks guys,
I was sure that there was a simple(?) and elegant solution . It is nice to see how much useful discussion it has generated.
Now back to my code....
Thanks heaps,
Lee
Lee -.-
Which would have not happened if we had a multi UART example STDIODEMO. (or people just knew whwt to do :( )
Joerg needs to be sacked. :lol: :lol:
It would still be nice to know why and how my original code worked being in such a mess.
Patches welcome! :D
Hi all,
Yep it works very nicely now. The avr-libc example project make much more sense to me too now.
One problem(?) that I still come get is the following warnings:
warning: initialization from incompatible pointer type
(twice)from the line
FILE com1_str = FDEV_SETUP_STREAM (uart0_putchar,uart0_getchar, _FDEV_SETUP_RW);
I have tried various casts, but have had no success in
eliminating these warnings. I had similar problem when using fdevopen(...,...).
Is it possible to get rid of these errors or do I need to put up with them?
Lee
Lee -.-
Can you show the prototype for your getchar and putchar routines?
Cliff
Hi Cliff,
Here they are!
char uart0_getchar(void);
int uart0_putchar(char);
char uart1_getchar(void);
int uart1_putchar(char);
Lee
Lee -.-
But those don't follow what's given in the manual:
The prototype for the putchar's should be:
int    uart_putchar(char c, FILE *stream)
and for the getchar's it is:
int uart_getchar(FILE *stream)
You may want to look at how this is done in the worked example in the user manual:
Also here
you are assigning com1_str to uart0 instead of uart1.
The 2 USART.c and .h files I posted are just the stdiodemo modified files for USART0 and USART1 to work with newer chips.
These are the updated files as suggested by Arnold.
Well done Cliff! I will always be humble in your presence!
I would have avoided this problem in the first place if had used uart.c (but I would not have learnt as much either)!
Lee
For those who may stumble accross this thread in the future, here are the salient lines.
______________________________________________________
int uart0_getchar(FILE *);
int uart0_putchar(char c, FILE *);
int uart1_getchar(FILE *);
int uart1_putchar(char c, FILE *);
FILE com1_str = FDEV_SETUP_STREAM(uart0_putchar,uart0_getchar, _FDEV_SETUP_RW);
FILE com2_str = FDEV_SETUP_STREAM(uart1_putchar,uart1_getchar, _FDEV_SETUP_RW);
#define com1 (&com1_str) //alias
#define com2 (&com2_str) //alias
//and in main
init_uarts(); //set baud rates etc.
stdout=stdin=stderr=com1;
printf("Change connector to com2 & press any key");
fgetc(com2);	//wait for key press on com2
fprintf(com2, "Good you found the any key");
& finally the low level drivers for uart n
int uartn_getchar(FILE *stream)
	loop_until_bit_is_set(UCSRnA, RXCn);
	return	UDRn;
static int uartn_putchar(char ch, FILE *stream)
      loop_until_bit_is_set(UCSRnA, UDREn);
      UDRn = ch;
      return 0;
Lee -.-
