Question on program memory and structure
5 posts / 0 new
#include
typedef struct {
	unsigned int a;
	unsigned char b;
}dataStruct;
const dataStruct data PROGMEM  = {0xfe02, 0x01};
int main()
	unsigned int readData;
	readData = pgm_read_word(data.a);
	while(1){
	return 0;
I'm trying to read data from structure in program memory. Can I do like above code (not work after I test) ? Or I need to use memcpy_P copy to RAM before use it?
Thank.
I think you might need
pgm_read_word(&data.a)
because (I assume that) pgm_read_word takes an address as a parameter.
Nigel Batten
www.batsocks.co.uk
OK it work, thank you.
More question, if I read by pass a program memory pointer.
const dataStruct *data_P PROGMEM  = &data;
readData = pgm_read_word( pgm_read_word(&data_P->a) );
What is the correct way ?
Try this:
typedef struct {
   unsigned int a;
   unsigned char b;
}dataStruct;
dataStruct* tmp_ptr = (dataStruct*)pgm_read_word(&data_P);
readData = pgm_read_word( &tmp_ptr->a );
