Hello All,
I have just joined and have a tech problem with the AVRprog.
When I run AVRprog or use AVRstudio 4 I get :
"No supported baord found! AVRprog version 1.40"
It is connected on COM1 via a full straight serial cable. It is correctly powered up and it works perfectly when using an inhouse custom program.
I am an experenced engineer, so it is not some daft problem like I have left the COM port open.
I have tried a couple of AVRprogrammers and they all do the same thing.
Any suggestions ?
Thanks for your help
Dren
