Atmega88 locking up
11 posts / 0 new
I have designed an electronic keypad lock using an Atmega88. We are testing the product at the moment and it works well. The problem is that after say 3000 operations the lock to seems to freeze, the only way to get operational is to reset.
Without going into lots of detail could anyone point me in a direction where to look. I am sure the lock works fine when used occasionally as we have had models working for months. It seems the constent operations are effecting it.
thanks
James
Usual culprits are memory leaks, write through rogue pointer, stack corruption, other form of RAM corruption.
Lucky for you the mega88 supports debugWire so it should be possible to "look inside" a failing unit and see what's going on.
Cliff
PS Do you really think a thread title of "Help!" is a useful name for the topic? Also I see no relevance to GCC in this post.
Cliff,
Sorry first thought was its done in C so ill post there but in hind sight general AVR would have been best.
I think you right about debug wire, to be fair i thought i would rack peoples brains as i am sure its something simple and there is nothing better than experience to find this out.
thanks
James
Well things that take minutes/hours to occur are, like I say, often a sign of something going slowly wrong such as a memory leak that builds up over time (though in a mega88 I doubt you'd be using malloc/free anyway?).
Another one is an inbalnaced stack where each time "something" is done the stack descends by one/two more bytes. Eventually it "bumps into" something and all hell breaks loose.
But 3,000 operations to failure suggests it cannot be, for example, one byte lost on each operation as the mega88 doesn't have 3,000 bytes to "use up".
'course it could be a hardware rather than a software issue. Maybe 3,000 operations is as long as it takes for the battery to drain to a level where the Vcc dops off and the CPU latches up because BOD was not enabled?
Cliff,
Reguards the batteries, the lock after reset will work again for another few thousand operations. I am sure its something in my program as i know i aint the best programmer around. I was thinking it could be to do with poor handling of my variables.
What i am not sure of at the moment is if the lock has frozen or if it is in sleep mode and wont wake up. The lock spends all its time in sleep apart from when a button is pressed it then stores the numbers in an array of Char (4 numbers) and compares it to a stored value. If correct the lock opens if incorrect it goes back to sleep.
I have attached the scematic of the lock for reference if it helps.
[img]
gougam,
This is where most of the members will ask to see your code if possible. It could be something simple.
A
AVR Studio 4 Ver. 4.18 684
avr-gcc Ver. 4.3.0
ISIS 7
ELECTRA
Here is the code, and yes i know its messy.
#include "keypad.h"
cli(); // Turn off interupts
initialise(); // Initialise Ports
	while (1) //loop key check forever
			while (pos < size) // while code is not entered loop
				if (pos == 0) // If in first loop do nothing
					toc++;	// Add one to timer for time outr function
					if (timeout == 1) // if time out is set
							if (toc == 41000)	//if button timed out
									wrong();
									// clear Keycode 1-4 and cancel program mode
									clear();
				DDRD = 0xFF;
		 		PORTB = 0b01111111;
				//check for rows and send key number to portD
				//instead sending key number to PORTD you can use
				// any function that serves pressed button
				//first column
				if (!(bit_is_set(PINB, 0))) // Is button 3 being pressed
					if ((prognew == 1)||(prognew == 2)||(prognew == 3))	//if changing code
							code[pos] = 3;
							set();
							while (!(bit_is_set(PINB, 0)))
								hold(0);
					else if (prognew ==0)	//if inputing code
						keycode[pos] = 3;
						set();
								hold(0);
				if (!(bit_is_set(PINB, 1)))	// Is button 2 being pressed
							code[pos] = 2;
							set();
							while (!(bit_is_set(PINB, 1)))
								hold(1);
						keycode[pos] = 2;
						set();
								hold(1);
				if (!(bit_is_set(PINB, 2)))	// Is button 1 being pressed
							code[pos] = 1;
							set();
							while (!(bit_is_set(PINB, 2)))
								hold(2);
					else if (prognew == 0)	//if inputing code
						keycode[pos] = 1;
						set();
								hold(2);
				//second column
				PORTB =0b10111111;
				if (!(bit_is_set(PINB, 0)))	// Is button 6 being pressed
							code[pos] = 6;
							set();
								hold(0);
						keycode[pos] = 6;
						set();
								hold(0);
				if (!(bit_is_set(PINB, 1)))	// Is button 5 being pressed
							code[pos] = 5;
							set();
								hold(1);
						keycode[pos] = 5;
						set();
								hold(1);
				if (!(bit_is_set(PINB, 2)))	// Is button 4 being pressed
							code[pos] = 4;
							set();
								hold(2);
						keycode[pos] = 4;
						set();
								hold(2);
				//third column
				PORTB =0b11011111;
				if (!(bit_is_set(PINB, 0)))	// Is button 9 being pressed
							code[pos] = 9;
							set();
								hold(0);
						keycode[pos] = 9;
						 set();
								hold(0);
				if (!(bit_is_set(PINB, 1)))	// Is button 8 being pressed
							code[pos] = 8;
							set();
								hold(1);
						keycode[pos] = 8;
						set();
								hold(1);
				if (!(bit_is_set(PINB, 2)))	// Is button 7 being pressed
							code[pos] = 7;
							set();
								hold(2);
						keycode[pos] = 7;
						set();
								hold(2);
				//fourth column
				PORTB =0b11101111;
				if (!(bit_is_set(PINB, 2)))	// Is button C being pressed
							wrong();
							//restore code to previouse value
							restore();
							clear();
								hold(2);
							if (canc == 1)
									wrong();
									clear();
									op = optemp;
									masttemp = 0;
									prognew = 0;
									//tempmast = 1;
									canc = 0;
							else if (op == 2)
									wrong();
									tempop = 1;
									clear();
									prog = 2;
									prognew = 0;
									pos = 0;
									wrong();
									prognew = 0;
							// clear Keycode 1-6 and cancel program mode
							clear();
								hold(2);
				if (!(bit_is_set(PINB, 0)))	// Is button P being pressed
							wrong();
							restore();
								hold(0);
							if (pos == 0)
								if (res == 0)
									Reset();
								else if (tempop == 2 || tempop == 3)
										wrong();
										clear();
										progflash();
										//program mode and clear all Keycodes
										prog = 1;
										pos = 0;
										size = 6;
										toc = 0;
										timeout = 1;
									hold(0);
								wrong();
								clear();
				if (!(bit_is_set(PINB, 1)))	// Is button 0 being pressed
							code[pos] = 0;
							set();
								hold(1);
						keycode[pos] = 0;
						set();
								hold(1);
				res = 1;
				if (prog == 1 && op == 1) //if in single user mode and in program mode
						if (pos == 4)
								if ((keycode[0] == code[0])&&(keycode[1] == code[1])&&(keycode[2] == code[2])&&(keycode[3] == code[3]))
										keycode[4] = 'n';
										keycode[5] = 'n';
										pos = 6;
				if (pos == 0)
					if (prog == 1)
						{	// Sleep set up
							PORTB =0b00001111;
							DDRD=0xF9;
							PORTD =0b01111010;
							cli();
							//PRR =0xFF;
							//EICRA = _BV(ISC00) | _BV(ISC01);	// Rising edge of INT0 generates an interrupt
							EICRA = (0<<ISC00) | (0<<ISC01);
							EIMSK = _BV(INT0);	// External inerrupt enable
							set_sleep_mode(SLEEP_MODE_PWR_DOWN);
							sei();	// Enable global interrupts
							sleep_mode();  // go to sleep
				if (op == 3) //if in change master code mode
								if (masttemp == 1)
									if ((keycode[0] == codeM2[0])&&(keycode[1] == codeM2[1])&&(keycode[2] == codeM2[2])&&(keycode[3] == codeM2[3])&&(keycode[4] == codeM2[4])&&(keycode[5] == codeM2[5]))
											codeM1[0] = keycode[0];	// if new master code is correct two times store
											codeM1[1] = keycode[1];
											codeM1[2] = keycode[2];
											codeM1[3] = keycode[3];
											codeM1[4] = keycode[4];
											codeM1[5] = keycode[5];
											progflash();
											progflash();
											eeprom_write_block(&mast, (void*)16, 2);
											eeprom_write_block(&codeM1, (void*)18, 6);
											tempmast = 1;
											clear();
											op = optemp;
											prognew = 0;
											if (op == 1)
													relaod();
											wrong();
											clear();
											prognew = 0;
											op = optemp;
											masttemp = 0;
											tempmast = 1;
											//prognew = 0;
											if (op == 1)
													relaod();
								relaod();
								if ((keycode[0] == code[0]) && (keycode[1] == code[1]) && (keycode[2] == code[2]) && (keycode[3] == code[3]))
										wrong();
										clear();
										prognew = 0;
										op = optemp;
										masttemp = 0;
										tempmast = 1;
										//prognew = 0;
										if (op == 1)
												relaod();
										codeM2[0] = keycode[0]; // temp store new master to check against
										codeM2[1] = keycode[1];
										codeM2[2] = keycode[2];
										codeM2[3] = keycode[3];
										codeM2[4] = keycode[4];
										codeM2[5] = keycode[5];
										clear();
										prognew = 0;
										size = 6;
										if (tempmast == 0)
												masttemp = 1;
												progflash();
										tempmast = 0;
				if (op == 2) // if in multi user mode
						if (prog == 1)
							if (tempop == 1) // if new code is being entered
								if (masttemp == 1)
										masttemp = 0;
										size = 4;
										prognew = 0;
										code[0] = keycode[0]; // Store new code
										code[1] = keycode[1];
										code[2] = keycode[2];
										code[3] = keycode[3];
										ADC_Convert();		  	// Check battery voltage
										lock();
										progflash();			// Flash LED
										progflash();
										tempop = 3;				// Set mode to check for new code to open
										prog = 2;
										prognew = 0;
										pos = 0;
										clear();
										//Double enter code removed to put back in remove above and use below
										//progflash();			// Flash LED
										//tempop = 2;				// Set mode to check for new code to open
										//prog = 2;
										//clear();
										//prognew = 0;
										//pos = 0;
							else if (tempop == 2)
									if ((code[0] == keycode[0]) && (code[1] == keycode[1]) && (code[2] == keycode[2]) && (code[3] == keycode[3]))
											lock();
											progflash();
											prog = 2;
											prognew = 0;
											pos = 0;
											clear();
											wrong();
											tempop = 1;
											clear();
											prog = 2;
											prognew = 0;
											pos = 0;
							else if (tempop == 3)		// If in open mode
										op2func();		// Open lock
								else if	((keycode[0] == codeM1[0])&&(keycode[1] == codeM1[1])&&(keycode[2] == codeM1[2])&&(keycode[3] == codeM1[3])&&(keycode[4] == codeM1[4])&&(keycode[5] == codeM1[5]))
										op2func();		//Open lock
								else if ((keycode[0] == codeM1[0])&&(keycode[1] == codeM1[1])&&(keycode[2] == codeM1[2])&&(keycode[3] == codeM1[3])&&(keycode[4] == 'n')&&(keycode[5] == 'n'))
										master(); //If it looks like master code is being entered allow two extra numbers to be added
								else if (masttemp == 1)
										masttemp = 0;
										size = 4;
										prognew = 0;
									prog = 3;	//If code is not good start again
									pos = 0;
									clear();
									wrong();
				timeout = 0;
				if (prognew == 1) // Change mode
					if (user == 0)
							if ((code[0] == mode1[0]))
								progflash(); //Set to Single user mode
								lock();
								op = 1;
								prognew =2;
								clear();
								prog = 3;
							else if ((code[0] == mode2[0]))
								unlock();
								progflash();	//Set to multi user mode
								progflash();
								op = 2;
								clear();
								prog = 3;
								prognew = 0;
							else if ((code[0] == mode3[0]))
								progflash();	// To change master code
								optemp = op;
								op = 3;
								clear();
								canc = 1;
								size = 6;
								prognew = 0;
								wrong();	//If wrong mode entered start agin.
								clear();
								prognew = 0;
								restore();
							if ((code[0] == mode4[0]))
									progflash(); //Set Single user mode code if using user code to change
									//lock();
									op = 1;
									prognew = 3;
									clear();
									prog = 3;
									//user = 0;
									clear();
									prognew = 0;
									restore();
									user = 0;
				else if (prognew == 3)
						tempcode[0] = code[0];
						tempcode[1] = code[1];
						tempcode[2] = code[2];
						tempcode[3] = code[3];
						progflash();
						clear();
						prognew = 2;
						prog = 3;
				else if (prognew == 2)
							if (user == 1)
									if ((tempcode[0] == code[0])&&(tempcode[1] == code[1])&&(tempcode[2] == code[2])&&(tempcode[3] == code[3]))
											if ((code[0] == codeM1[0]) && (code[1] == codeM1[1]) && (code[2] == codeM1[2]) && (code[3] == codeM1[3]))
													wrong(); //If wrong code start again
													//Clear Keycode
													clear();
													prog = 2;
													pos = 0;
													user = 0;
													prognew = 0;
													relaod();
													delay(1);	//When new code is entered store into eeprom
													eeprom_write_block(&code, (void*)12, 4);
													progflash();
													progflash();
													prognew = 0;
													prog = 2;
													pos = 0;
													user = 0;
											//Clear Keycode
											clear();
											prog = 2;
											pos = 0;
											user = 0;
											prognew = 0;
											relaod();
											//Clear Keycode
											clear();
											prog = 2;
											pos = 0;
											user = 0;
											prognew = 0;
											relaod();
											//Replpace code
											progflash();
											progflash();
											prognew = 0;
											prog = 2;
											pos = 0;
				if ((prog == 0)&&(op == 1))		//if not in program mode and in single user mode
								ADC_Convert(); //Check battery
								op1func();		//Open lock
								master();		//If it looks like master code is being entered allow two more numbers
								masttemp = 0;
								size = 4;
								prognew = 0;
								//Clear Keycode
								clear();
								prognew = 0;
				else if (prog == 2) //Dummy mode
						prog = 0;
				else if (prog == 1)
							progflash(); //Enter program mode
							//Backup old code
							backup();
   							//Clear Keycode
							pos = 0;
							prognew = 1;
							size = 1;
					else if ((keycode[0] == code[0])&&(keycode[1] == code[1])&&(keycode[2] == code[2])&&(keycode[3] == code[3])&&(keycode[4] == 'n')&&(keycode[5] == 'n'))
							//Backup old code
							backup();
   							//Clear Keycode
							pos = 0;
							prognew = 1;
							size = 1;
							user = 1;
							wrong();
							clear();
void hold(char pin) //Function for hold button
	char i;
		for (i = 1; i <=10; i++)
				if (bit_is_set(PINB, pin))
						i = 11;
				delay(10);
				if (i == 10)
						clear();
void clear() //Function to clear all data
		pos = 0;
		prog = 0;
		timeout = 0;
		size = 4;
		keycode[0] = 'n';
		keycode[1] = 'n';
		keycode[2] = 'n';
		keycode[3] = 'n';
		keycode[4] = 'n';
		keycode[5] = 'n';
void backup() //Back up of old code function
		codeback[0] = code[0];
		codeback[1] = code[1];
		codeback[2] = code[2];
		codeback[3] = code[3];
void restore()	//Restore back up if failure in new code
		code[0] = codeback[0];
		code[1] = codeback[1];
		code[2] = codeback[2];
		code[3] = codeback[3];
		prognew = 0;
		timeout = 0;
void flash (char f, char t, char c) //Flash LED function
	char i;
		if (c == R)
				for (i = 0; i < f; i++)
					 	PORTD = 0x87;
						delay(t); //delay 0.25s
						PORTD = 0x47;
						delay(t);
		else if (c == G)
					 	PORTD = 0xC5;
						PORTD = 0x47;
						delay(t);
void delay(char del) //Software timer function
	char n;
		for (n = 0; n <= del; n++)
				_delay_loop_2(5000);
// External interrupt ISR
ISR(INT0_vect)
		cli(); //Turn off interupts
		DDRD=0xFF;
		PORTD=0x47;
		//PRR =0xEE;
		EIMSK = !_BV(INT0); //Return to main code
void wrong() //Wrong code function
		flash(8,1,R);
		size = 4;
void button() //Button press LED function
		flash(1,3,G);
void progflash() //Program LED function
		flash(1,20,G);
void set() //Button press setup function
		toc = 0;
		timeout = 1;
		pos = pos + 1;
		button();
void lock() //Lock function
		PORTD = 0xD8;
		_delay_loop_2(10000);
		PORTD = 0x47; // motor control into sleep
void unlock() //Unlock function
		PORTD = 0xE8;
void master() //If mode requires two more numbers for master code function
		pos = 4;
		prog = 2;
		size = 6;
void op1func() //Single user mode unlock function
	//	flash(1,25); //Long single green flash
		unlock();
		flash(4,25,G); //Second green flash
		lock();
		flash(1,25,G);
		//Clear Keycode
		clear();
void op2func() //Multi user mode unlock function
		progflash();
		unlock();
		progflash();
		code[0] = 'n';
		code[1] = 'n';
		code[2] = 'n';
		code[3] = 'n';
		tempop = 1;
		prog = 2;
		prognew = 0;
		pos = 0;
		clear();
void initialise() // Initialse program
		relaod();
	//	PRR = 0xEE; //remove if problem added 13/05/08 not tested
		//high for output(columns) low for input(rows);
		uint8_t check[2];
		eeprom_read_block((void*)&check, (const void*)16,2);
		if (check[0] == 1 && check[1] == 1)		// if a master code has been changed read in new code
				uint8_t codeM1temp[6];
				eeprom_read_block((void*)&check, (const void*)18,6);
				codeM1[0] = codeM1temp[0];
				codeM1[1] = codeM1temp[1];
				codeM1[2] = codeM1temp[2];
				codeM1[3] = codeM1temp[3];
				codeM1[4] = codeM1temp[4];
				codeM1[5] = codeM1temp[5];
		DDRB=0xF0;
		//enable internal pullups for PB0-PB3
		PORTB=0x0F;
		//Port D
		DDRD=0xFF;
		PORTD=0x47;
		lock();
		//Port C
		DDRC=0x0F;
		PORTC=0x00;
		clear();
void ADC_Convert() //Check battery funtion
		ADMUX   = 0x4E;  // set Vcc as ref and internal ref 1.2V as input
	   	ADCSRA  =   (1 << ADEN)|(1 << ADPS2)|(0 << ADPS1)|(1 << ADPS0); // turn on ADC and set speed
	   	ADCSRA |= (1 << ADSC); //start dummy conversion
	   	while(!(ADCSRA & 0x10)) ; //Dummy step
	    vcc = ADC;				// take reading
		ADCSRA = (0 << ADEN);
	    vcc = vcc >> 3;
		if (vcc >= 56)
				flash(8,1,R);
		else if (vcc >= 52)
				flash(4,1,R);
void relaod()
		uint8_t code1[4];
		eeprom_read_block((void*)&code1, (const void*)12, 4);
		code[0] = code1[0];
		code[1] = code1[1];
		code[2] = code1[2];
		code[3] = code1[3];
void Reset()
		char g;
		for (g = 1; g <=10; g++)
				if (bit_is_set(PINB, 0))
						g = 11;
				delay(50);
				if (g == 10)
						codeM1[0] = 6;	// if new master code is correct two times store
						codeM1[1] = 5;
						codeM1[2] = 4;
						codeM1[3] = 3;
						codeM1[4] = 2;
						codeM1[5] = 1;
						progflash();
						progflash();
						clear();
Here is the header file
#define F_CPU 4000000UL  // 4 MHz
#include
#include
#include
#include
#include
#include
#include
#include
//#define eeprom_is_ready  ()
void hold(char);
void clear(void);
void backup(void);
void restore(void);
void flash (char, char, char);
void delay (char);
void timer0_init(void);
void wrong(void);
void set(void);
void progflash(void);
void initialise(void);
void lock(void);
void unlock(void);
void master(void);
void op1func(void);
void op2func(void);
void ADC_Convert(void);
void relaod(void);
void Reset(void);
// Delcare globals
int pos = 0;
char prog = 0;
char prognew = 0;
int size = 4;
char keycode[6] = {'n','n','n','n','n','n'};
char code[4] = {'n','n','n','n'};
char codeM1[6] = {6,5,4,3,2,1};
char codeM2[6];
char mode1[1] = {1};
char mode2[1] = {2};
char mode3[1] = {0};
char mode4[1] = {3};
char op = 1;
char tempop =1;
char codeback[4] ;
char timeout = 0;
unsigned toc;
unsigned vcc;
char optemp;
char masttemp = 0;
char tempmast = 0;
char canc = 0;
char mast[2] = {1,1};
char user = 0;
char tempcode[4];
char res = 0;
char G ='G';
char R ='R';
//char mode;
//char vcc2[]= {'0','0','0','\0'};
First step is to get readable code that gives you a fair chance to spot the error/problem...
That first if-statement (the "do-nothing" one) is totally meaningless. Delete it. Or are you actually missing an "else"? The indentation suggests the latter.
After that you have all those nearly-identical if-blocks. Break the code in them out to a function to reduce your code size with maybe 50%.
And then...
You have a lot of these comparisons. Break them out to a testing function, eg
bool MatchCode( char code1[], char code2[]) { ... }
so that you can
if ( MatchCode( keycode, codeM1 ) ) ...
Keep on doing such refactorings and you will find that the code might shink considerably, and that doesn't just save FLASH but actually gives you a fair chance to spot a problem/error.
goujam,
You may want to use want to use the delay routines included in . It makes timing more controllable and at least the delay settings can be related to real time.
I also notice you are comparing arrays byte by byte. This is easier to do with strcmp(). You can also use strcpy() for copying data. Although I have not seen it in the library reference, it should be easy to produce your own memcpy()and memcmp().
A
avr-gcc Ver. 4.3.0
ISIS 7
ELECTRA
Thanks Johan and Andrew ill spend today cleaning the program up. Over the weekend i have been having a think about this problem too. I am now wondering if there is a problem with the PRR Register command i put in.
Anyway ill work at my code again and get back with my results.
James
