USB vs AT90USB
11 posts / 0 new
This is related to USB:
Which method has better data transmission speed over other:
1. ATmega8 with HID
2. Special USB controllers
3. FTD232 etc ICs
4. BF-810
Experienced inputs are requested.
> 1. ATmega8 with HID
Slowest, as the USB is in software -- you use most of the AVRs cycles to generate the signals, and you only get single banked Low Speed (1.5Mb/s).
The USB AVRs are better. You can get Full Speed double banked data out of them - up to 12Mb/s which is faster than you'll be actually be able to process at.
> 3. FTD232 etc ICs
Easy to use, but requires an external chip, and is expensive. Virtual serial ports can be SLOW depending on the way they are used.
> 4. BF-810
Never heard of it.
- Dean :twisted:
abcminiuser wrote:
> 1. ATmega8 with HID
> 3. FTD232 etc ICs
> 4. BF-810
Never heard of it.
- Dean :twisted:
Thus your analysis says the special USB controllers are fast.
The BF-810 is BAFO make USB to serial conv product.
Hey,
Any of the AT90USB devices are going to be much faster than external hardware. The reason being the USB controller is inside your AVR, connected by the internal databus.
Anything external needs a slower method of communication. And the controllers built into the AVRs are quite good, and even better if you use Dean's USB library ;-)
-Colin
Can you add its link here!!
Just scroll up a bit, the link is in 'abcminiuser' signature! It's called 'MyUSB'.
-Colin
Dean's USB library
You are welcome
Thomas
Edit:
Hint: it is the first link. Alternatively, google for MyUSB
pycrc -- a free CRC calculator and C source code generator
Lazy me :roll:
The 90USB1287 will cost me US$15 in my region, whats the cost at your end? Do you get single pieces for R&D. Here the reseller has MOQ 5.
Do you really need OTG and the biggest AT90USB device size possible? As you were comparing against mega8 then presumably not. In that case how about pricing up an AT90USB82 for example. I think you'll find that Digikey (who lists the 1287 at $15.05) have this listed for $3.23 (one off). That drops to $2.17 for 100 of them.
Cliff
Or for experimenting and general use, get an AT90USBKEY at about US$30 that has lots of toyz.
Lee
Fer sure.
If your CPU is running at 8 MHz,
it has about 5 cycles to process each byte.
I did manage to do USB to SPI at just over 1 Mb/s.
The SPI was the bottleneck.
"SCSI is NOT magic. There are *fundamental technical
reasons* why it is necessary to sacrifice a young
goat to your SCSI chain now and then." -- John Woods
