1.8 tft with atmega 8515
17 posts / 0 new
Hi everyone, I just bought a cool 1.8" TFT display from Newhavendisplay and I wired it to my stk500 which has the atmega8515 on it. Now I'm trying to see if I can do anything on it, change a color, show a line, shit show a dot, but nothing seems to be working.
My Pin layout is as follows:
RD PB7
WR PB6
RS PB5
CS PB4
IMO PB3
RST PB2
PORTA = DB0-DB7
PORTC = DB8-DB15
Back light is also hooked on and comes on.
I'm using avr studio with gcc, I attached my code and I also put the documents in the zip file. I also called newhaven, they helped me with the initialization, but it's still not working. I figure it's something silly I'm not doing correctly.
Any help will be greatly appreciated.
*Edit: Sorry, the documents are too big to attach, here aer the links:
For the TFT:
http://www.newhavendisplay.com/i...
For the Driver:
http://trulylcds.com/tft/specs/D...
I would start by setting your ports to outputs.
Use the spi... just need 3 wires. Easier to hook up.
:oops: :oops: :oops: WOWOWOWWOW :oops: :oops: :oops:
Now thats embrassing, can't believe I forgot to change them to outputs. Going to test now, will post results.
Hmmm.. spi sounds like a good option too
Too bad they already decided which interface you can use (and can't use).
If you get something to display, post a picture.
Still no luck :(, hmmm.. im going to go back over my pins, but latest changes include:
DDRA= 0xFF;
DDRB= 0xFF;
DDRC= 0xFF;
and I just decided to gnd the IMO pin, since it needs to be low anyhow
Ahh so it was partially newhavens fault, on the doc pg 5 has reset as pin 4 and IM0 as pin 5, and on pg6 the pin connections show IM0 as pin4 and reset as pin5, after I spoke to tech support they told me 4 was IM0 and 5 is reset. So i'm able to change colors, but its not working as I wanted it to, I was trying to display a picture, by taken a pic, making it 16bit, then I use frhed hex editor to export a hexdump, but in said of the pic showing, I'm just getting a varies colors. I posted some of the pics, time to play around with it some more.
I should have been more specific on the meaning of 'something'. Just kidding. We still look forward to 'something' being displayed.
I realized the 8515 just didn't have enough memory or flash to program this tft, so I placed a stk501 on top of my stk500 with an atmega1281. I placed the connections for the LCD in the same expansion slots, but the LCD is changing colors or displaying anything.. Do you guys have any idea why that would happen?
I used the exact same pin layout.
RD PB7
WR PB6
RS PB5
CS PB4
IMO PB3
RST PB2
PORTA = DB0-DB7
PORTC = DB8-DB15
I also tried to take back out the stk501 and connect the lcd back to the expansion slots on the stk500 and it worked again, but when I put it in the stk501 expansion slots it doesn't work :(. The ISP is connected correctly, because I can program it, but no results...
dammit noob mistake, its working :oops: , forgot to remove the 8515 lol
edit okay, back to trying to display "something"
../LCDtest.c:577: error: size of variable 'pikachu' is too large
Has anyone seen this error? I think it might be because the array is too big?
yep thats the reason, I had to break the data into 2 arrays
Nope, sorry! I've never seen this error because I have never (and likely will never) name a variable "pikachu".
Mark
LOL, trying to show pikachu on the lcd :lol:
I really need to find an easier way to do this, geeeeez, I manage to get an H, on the screen, but my phone is dead, so no pics. Is there an easier way to program tfts? Like maybe a graphic accelerator, I'm currently researching 2D ones now
Here's a VGA controller specifically for embedded use that allows the use of graphics primitives.
Note that this is just the controller (not the video circuitry), and I highly doubt it would work with your TFT. It's the only thing I know of that's anything like what you're describing.
http://www.4dsystems.com.au/prod.php?id=15
Mark
Programing graphics is anythig but slow. Not too difficult, but a lot of work. My experience dictated that is a question of 'I like this' and 'I don't like this', a question of many fonts (a lot of work unless you have them prebuild or some program that build them for you), a question of Bitmaps and graphics, and memory to store the last ones.
If you do it for yourself, then do what you like, but be aware: you will need a long time and some tools. If you work for a company, try that the responsibles of the aestetics of the product fix what they want quite clearly before you begin to work.
Guillem.
