Datasheet AT45DB321 in SO8 package
3 posts / 0 new
I can't find the pinout for the AT45DB321 Dataflash in 8 pin SO8 housing. In Atmels Datasheet is only a description of the 44 pin CBGA and 32 pin TSOP housing.
Does anyone know the pinout for that IC in the 8 Pin Package?
Thank you
best regards
Mark
Title edited by Plons (mod)
Look for the datasheet of AT45DB321C. This one has the 8pin SOIC package.
http://atmel.com/dyn/products/pr...
-drt
I have used the AT45DB642 and inside the datasheet was a picture aof an 8 pin package, only for serial mode using of memory. Take a look it may be what you need.
Michael.
Michael.
User of:
IAR Embedded Workbench C/C++ Compiler
Altium Designer
