Will a USB->Paralel converter work for Xilinx?
15 posts / 0 new
Hi guys,
I just got my Xilinx spartan 3 devkit from JimW52, but there's a small problem on my end: I've got no parallel port anymore.
I know that there have been problems getting the ponyprog to run on USB->Parallel converters, so should I even buy the converter? If not, what would you recoment?
The programmer uses the parralel port of the computer, inside is I guess only some voltage convertion logic.
Thanks ,
David
If you have a laptop buy pcmcia or express card with lpt interface. If you have a stationary PC buy PCI card. If you haven't RS port too, you may buy single card with both, lpt and RS ports.
Don't forget that express card can be connected as PCI or USB. So if you get an USB one you will have same problems as classic USB 2 LPT.
It's been my experience that a USB to Parallel adapter only works with printers. I would be surprised if it worked with the parallel port of a Xilinx dev kit.
Does the Xilinx board also have a JTAG connector on it? You may be able to use a USB to JTAG adapter instead.
Yup, it does have a JTAG. The programmer is just a parralel -> JTAG thingie, I guess much like the ponyprog.
This is a USB version of the same cable, isn't it?
Might wanna try finding it at a lower price, though. Or - you could just buy a bunch of other cool stuff while you're at it :D
Daqq!
If you are contemplating to go for the Digilent cable that Thomas linked to then talk to me first. I've currently dragged up an old minitower PC with W2K just to program my Xilinx Spartan-3, and am getting quite tired of this sisutation. I'm planning to buy from Digilent this fall - you could ride your stuff "piggyback" on my order..
JTAG is not the only way to program the Spartan 3, it can also be programmed serially. You can create a .bit file and then send it via USB or RS232 to a micro which does the actual programming. http://everything2.com/e2node/In... gives the general idea.
Edit: change word order so it makes sense!
Your message here - reasonable rates.
You need a USB programmer if you don't have a proper parallel port, they are quite expensive.
Leon
Leon Heller G1HSM
daqq wrote:
Hi guys,
Thanks ,
David
If you have a PCI slot i suggest one of these
http://www.pollin.de/shop/shop.p...
I use this one
As i have killed a MoBo via the RS-232.
This way i just hope to kill the card.
/Bingo
Daqq,
Save yourslf the bullshit and send the kit to me! :lol:
Once again, Daqq: If you want one of those Digilent USB cables then PM me and we'll try to work something out, 'kay?
This is no general call - offer valid for Daqq only. If more people are interested then an organized group buy/shipping might be an option.
(I have been in contact with people at Digilent to assure me that that cable and the S3BOARD will be usable directly from Xilinx ICE WebPack, and not only from Digilents own programming software).
Experience so far:
PCI -> Parallel worked like a charm - it detected the whole JTAG chain.
That is until I used a wonderful PSU that gives good 5V/2A, but has a little problem - floating ground. After measuring it with an oscilloscope against the ground of the computer, the ground of the Xilinx devkit was +/- 150V different. It seems that the PCI card got borked.
Oh well, gonna look up the "Stupid things we do thread".
Was that the PSU that came with the S3 Kit ??
/Bingo
Nope, that was some other PSU I had from another thingie. The PSU from the kit had some weird socket on it, so I couldn't use that one.
Update: Seems I actually killed the cable - after replacing the card with a new one, the problem didn't go away.
