5V regulator gives 6.3 volts
9 posts / 0 new
i have an L7805CV regulator and istead of taking out 5V it takes out 6.3V!, i have 15 of the same chips and all takes out the same. i am puting in 14V from a power suply but i also tried an input from a power supply.
i have some ideas but i would like to hear your thoughts.
Thanks and Regards, Ran.
1. Is the ground pin connected properly?
2. Input and output decoupling capacitors?
3. Pin configuration? Read the data sheet. The 78L series have a different pin out from the TO220 types.
If you think education is expensive, try ignorance.
i found the problem, it is my multimeter, i cheked with a fluke and it is 5V constant.
Thanks emuler for the response.
Regards, Ran.
Run the multimeter over with your car!!
jim
jim
And after you do run that old meter over with your car, buy a good Fluke meter.
I would try replacing the battery in the multimeter first. It is real easy to forget that they have a battery!
Might save you the cost of another multimeter.
That's good advice. I know I was surprised the first time my Fluke starting giving incorrect readings and it only turned out to be the battery.
Also open the case and look for a calibration potentiometer. I got half a dozen cheapies from Harbor Freight that were up to 15 percent off. For $4 I'd guess there wasn't much time to adjust each unit!
Regards, Ran.
made in China
