Hi All,
In my GCC program:
fprintf_P(stdout,PSTR("Foo=%f\n"),5.0);
produces:
Foo=?
while:
fprintf_P(stdout,PSTR("Foo=%d\n"),5);
produces:
Foo=5
I am linking in:
libprintf_flt.a
libscanf_flt.a
Any idea why the float isn't recognized?
Hi All,
In my GCC program:
produces:
Foo=?
while:
produces:
Foo=5
I am linking in:
libprintf_flt.a
libscanf_flt.a
I would guess that you are not actually linking the libprintf_flt.a
Copy and paste the Studio Build Window for a complete compilation. ( Make clean first )
Make sure your makefile PRINTF_LIB value referst to the right library:
#Additional libraries. # Minimalistic printf version PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min # Floating point printf version (requires MATH_LIB = -lm below) PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt PRINTF_LIB = $(PRINTF_LIB_FLOAT) # Minimalistic scanf version SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min # Floating point + %[ scanf version (requires MATH_LIB = -lm below) SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt
avr-gcc.exe -mmcu=atmega168 -Wl,-Map=CushionController.map CushionController.o uart.o -lprintf_flt -lscanf_flt -o CushionController.elf
So, the correct libraries are linked in. The resulting elf file is about the size you'd expect with both of those libraries linked in.
If you use Mfile this would have been MUCH easier but the point is there are TWO things you must do to enable printf_flt support. The -l you show above is one half of the jigsaw the other, as show in an Mfile generated Makefile such as the one fizgig posted above is the need for:
-Wl,-u,vfprintf
So I guess your linker invocation should be:
avr-gcc.exe -mmcu=atmega168 -Wl,-Map=CushionController.map -Wl,-u,vfprintf CushionController.o uart.o -lprintf_flt -lscanf_flt -o CushionController.elf
But do yourself a favour and check out Mfile!
Oh and if you are using scanf as well you need the equivalent linker command for it too as shown in fizgig's post above.
