Accurate small current sensing
7 posts / 0 new
I'm needing to sense small currents (.02 - .6 mA) accurately.
I've been looking for transducers that are designed for this sort of thing, but I haven't been turning anything up in that low range.
I have also considered simply measuring and amplifying the voltage across a resistor. I can get some .1% tolerance 50 ohm resistors from digikey for not so much, but then when I think about amplification, I realize that my feed back resistor networks are going to suffer from considerably worse tolerances given the available resistor tolerances that I see.
I would like to have the entire system accurate to 1uA if possible.
It occurs to me that the I could use some fine variable resistors to tune the circuit in, but then I'm not sure what standard I might measure against?
Any suggestions appreciated.
B
If the current runs to ground or common and then an Op-amp with a negative voltage supply and a feedback resistor
could function as a virtual ground current-to-voltage converter. With a feedback resistor value of 5K Ohms the Op-amp
output would range from -0.1 to -3V for an input current of +0.02 to +0.6mA. A second Op-amp would be needed to
rescale for +V output if needed.
A wikipedia eaxmple.
Stan
Search for 'hi side current sensor' from max, lt, analog devices.
Use .1% resistors for all shunt and gain circuits and you will have .1% overall gain accuracy, which is pretty good, and meets your stated need.
Tom Pappano
Tulsa, Oklahoma
Another possibility is a hall effect sensor. This measures the magnetic field that the current produces when it runs through a wire. I IMAGINE it's possible to get very precise hall effect sensors but the overall accuracy of your system would depend on where you placed the sensor, ambient magnetic conditions, etc. I have no experience with that. 1uA is a tight spec. Good luck.
Piece of cake with LTC2484 (this is 24-bit ADC) and current sense resistor. However, precise reference is required.
If you are going to twiddle pots on each unit anyway, why not use stable resistors of any tolerance and store custom calibrations in firmware, assuming you can tolerate a divide or fixed point multiply.
For a reference, mechanical meters were accurate to a couple percent, 50 and 100 microamp movements were common in VOMs. Scrounge an old 20 Kohms-per-volt Simpson meter (or anything in a bakelite case :))
