I like to use cat5 cable cause I've got heaps of it lying around plus it is single core, so when you bend it into position it stays there.
The most annoying thing is that the insulation doesn't stand up to heat. I've have to solder joins very fast or else the insulation just shrivels away. Also it would be nice to have something a bit heavier.
