cbi(UCSR1B,UDRIE);
4 posts / 0 new
Why doesnt this work (mega128 | gcc version 3.0.4) :
sbi(UCSR1B,UDRIE);
sbi(UCSR0B,UDRIE); works fine.
I'm getting the folowing error:
serial.c: In function `_vector_32':
serial.c:40: warning: asm operand 0 probably doesn't match constraints
serial.c:40: inconsistent operand constraints in an `asm'
Eivind
*** Eivind, webmaster ***
Because UCSR1B is in the extended IO space.
IMO better is:
UCSR1B |= _BV(UDRIE);
UCSR0B |= _BV(UDRIE);
Using above syntax you can forget about IO space limitations and divisions. I think that two more instructions (but only a clock tick more) is not a big problem.
Reagrds,
Ahh, thanks. I havent read the datasheet for some time :)
Eivind
Also gcc 3.0.4 is getting pretty old. Update your tools.
Eric
