LCD Controller ST7529
2 posts / 0 new
Hi all,
I'm trying to get an ST7529 lcd controller to operate, i'm using it in 8bit (8080) parallel mode, I can read and write to/from the display without problem. But I can get nothing to be displayed, I'm using it in 3b3p mode.
VLCD seems to stay at 14.5 volts regardless what I do with the contrast/boost freq setting, V0 always seems to be low at 5.5v.
I have tried an external VLCD supply with no success either.
Does anyone have example init code, I have used the code in the datasheet so far.
Dave
"If it wasn't for bad luck I'd have no luck at all"
To answer my own question, x6 does not appear to work, going to x7 does however.
