Hi, I'm trying to use a make file created for avrdude (linux) and make it run on avr studio. It complies ok and reports..
Build started 12.8.2008 at 23:07:33 avr-gcc -Wall -Os -Iusbdrv -I. -mmcu=atmega8 -DF_CPU=12000000L -o main.bin usbdrv/usbdrv.o usbdrv/usbdrvasm.o usbdrv/oddebug.o main.o snes.o snesmouse.o nes.o db9.o devdesc.o -Wl,-Map=main.map rm -f main.hex main.eep.hex avr-objcopy -j .text -j .data -O ihex main.bin main.hex ./checksize main.bin ROM: 5128 bytes (data=116) RAM: 215 bytes Build succeeded with 0 Warnings...
But the start debug is gray'd out. I'm lead to believe it is do to the make file.. It seems the device is configured right as far as I can tell..?
Can anyone tell me what may have to change, I first thought the linux commands would need to come out but apparently the avr-gcc understands them.
UISP = uisp -dprog=stk500 -dpart=atmega8 -dserial=/dev/ttyS1 COMPILE = avr-gcc -Wall -Os -Iusbdrv -I. -mmcu=atmega8 -DF_CPU=12000000L #-DDEBUG_LEVEL=1 COMMON_OBJS = usbdrv/usbdrv.o usbdrv/usbdrvasm.o usbdrv/oddebug.o main.o HEXFILE=main.hex OBJECTS = usbdrv/usbdrv.o usbdrv/usbdrvasm.o usbdrv/oddebug.o main.o snes.o snesmouse.o nes.o db9.o devdesc.o # symbolic targets: all: $(HEXFILE) .c.o: $(COMPILE) -c $< -o $@ .S.o: $(COMPILE) -x assembler-with-cpp -c $< -o $@ # "-x assembler-with-cpp" should not be necessary since this is the default # file type for the .S (with capital S) extension. However, upper case # characters are not always preserved on Windows. To ensure WinAVR # compatibility define the file type manually. .c.s: $(COMPILE) -S $< -o $@ clean: rm -f $(HEXFILE) main.lst main.obj main.cof main.list main.map main.eep.hex main.bin *.o usbdrv/*.o main.s usbdrv/oddebug.s usbdrv/usbdrv.s # file targets: main.bin: $(COMMON_OBJS) snes.o nes.o snesmouse.o db9.o devdesc.o $(COMPILE) -o main.bin $(OBJECTS) -Wl,-Map=main.map $(HEXFILE): main.bin rm -f $(HEXFILE) main.eep.hex avr-objcopy -j .text -j .data -O ihex main.bin $(HEXFILE) ./checksize main.bin flash: all $(UISP) --erase --upload --verify if=$(HEXFILE) flash_usb: sudo avrdude -p m8 -P usb -c avrispmkII -Uflash:w:$(HEXFILE) -B 1.0 # Fuse high byte: # 0xc9 = 1 1 0 0 1 0 0 1 <-- BOOTRST (boot reset vector at 0x0000) # ^ ^ ^ ^ ^ ^ ^------ BOOTSZ0 # | | | | | +-------- BOOTSZ1 # | | | | + --------- EESAVE (don't preserve EEPROM over chip erase) # | | | +-------------- CKOPT (full output swing) # | | +---------------- SPIEN (allow serial programming) # | +------------------ WDTON (WDT not always on) # +-------------------- RSTDISBL (reset pin is enabled) # Fuse low byte: # 0x9f = 1 0 0 1 1 1 1 1 # ^ ^ \ / \--+--/ # | | | +------- CKSEL 3..0 (external >8M crystal) # | | +--------------- SUT 1..0 (crystal osc, BOD enabled) # | +------------------ BODEN (BrownOut Detector enabled) # +-------------------- BODLEVEL (2.7V) fuse: $(UISP) --wr_fuse_h=0xc9 --wr_fuse_l=0x9f fuse_usb: sudo avrdude -p m8 -P usb -c avrispmkII -Uhfuse:w:0xc9:m -Ulfuse:w:0x9f:m -B 10.0
