Possible glob() problem ?
2 posts / 0 new
On an Atmel NGW100 dev kit (atngw100-base_defconfig), I appear to have a slight problem with glob().
Can someone else confirm the following code ?
Create an empty file /etc/avahi/services/ssh.service. Then run the code.
Both glob() calls work (globret = 0).
If you delete the line "errno = 0;", then the second glob() fails (globret = 2).
Regards
Mark
#include
#include
#include
#include
int main(void) {
   glob_t globbuf;
   int globret;
   memset(&globbuf, 0, sizeof(globbuf));
   globret = glob("/etc/avahi/services/*.service", GLOB_ERR, NULL, &globbuf);
   printf("test globret = %d\n", globret);
   globfree(&globbuf);
   unlink("/tmp/missing_file");
   errno = 0;
   globfree(&globbuf);
Fixed.
It would appear that I needed to enable the extra uClibc setting UCLIBC_HAS_GNU_GLOB
