ATMega16 Output Compare Question
5 posts / 0 new
Hello-
I'm trying to setup output compare to generate a interrupt ever 500ms or a half a second.
I'm using a ATMega16 and a 6.00Mhz crystal.
This is the code I have its seems like it generates a interrupt ever 4 secondes... I'm using prescaler of 64.
r16 temp
r17 temp2
ldi temp, 1<<OCIE1A ;oc1a interrupt on
out TIMSK, temp
ldi temp, (1<<WGM12)+(1<<CS11)+(1<<CS10) ;mode4
out TCCR1B, temp
ldi temp2, 0xB7 500ms per avrcalc 6Mhz.
ldi temp, 0x1a
out OCR1AH, temp2
out OCR1AL, temp
Is this correct? Any comments?
Thank you
Don
If you thought you were running on the external crystal, but were actually running on the default internal oscillator (default fuse settings), you would get 3 seconds between interrupts.
Hi
Ok I didn't make any changes to fuses. This is the first project using atmega16. I will check out the data sheet.
Thank you
Don
Then you are running on the internal oscillator.
Data sheet page 23, Default Clock Source.
Hi
That did it! Running correctly now.
Thanks again.
Don
