Simple pwm question, plz help!
4 posts / 0 new
I am using ATmega8.
I am trying to understand pwm set-up. I read many tutorials but I want confirmation that I undestand it.
For pwm, timer goes up and down to a TOP value, there is a compare level (OCR1AH, OCR1AL). When the timer reach this levels, a flag is shown.
So for me, the compare level set the duty cycle and the TOP level the frequency.
However, I do not understand how to set the actual value of the TOP... I dont understand where this is define.
Sorry for this stupid question... :oops:
Many thanks!
Somewhere in the data sheet, in the section for the timer you are using, there is a table with the different timer modes. In this table there is a column where it is stated what is used as the TOP value for each mode. For some modes it is a constant fixed value (eg 0xFF), for others it is the value in a register (eg ICR1 or OCR1A).
this sample code runs at atmega8 16MHz and put a led to OC1A pin (PB1) to see the result. hope it'll help you
	TCCR1A = 0x82;		//inverting fastPWM mod 14
	TCCR1B = 0x1D;		//1024-prescaler
	ICR1 = 15624;		//freq = 1Hz
	OCR1A = 7812;		//duty = 50%
Thank you both for your help.
