How to make a pointer to an array of structures?
4 posts / 0 new
Hello everybody :D
I just can't seem to get something right.
I want to use a pointer to an array of structures
struct foo{int A, int B}foo_array[10];
struct foo *ptr1; // declare pointer to struct
prt1 = foo_array; // assign address of foo_arrary[0]
for(i=0;i<10;i++, ptr1++)
 ptr1->A = 1;
I would expect that all the values of A are set to 1 as a result, but this is not the case.
This is not the exact code, but very simular to what I am actually using.
Anyone got suggestions?
"Digital is a special case of analog" - George Philbrick
Hi xenobinol,
what compiler are you using? the code snipped you posted does not compile on GCC for several reasons:
1) The structure declaration is wrong: you can't use colons in the variable definition. I don't know what your struct is, probably an aggregate of 3 int variables: "A", "int" and "B". A valid definition would be
struct foo{ int A; int B; } ...
2) prt1 does not exist
3) i does not exist
Please post code we can compile and run on the target. I suspect that during the process of shaping the code into a presentable form you'll find the error yourself.
If not, please post a syntax-correct file and we will be happy to test it.
HTH
Thomas
pycrc -- a free CRC calculator and C source code generator
PS: I tend also to simplify struct declarations by using "typedef", e.g.
typedef struct { int A; int B; } foo_t;
foo_t foo_array[10];
foo_t *ptr1;
Thomas
foo_t *ptr1;
Thomas
Ok, thanks Thomas for your interest, I apologize for the typos
I made use of your tip about the typedef statement, good idea :idea:
I had some problems with my hardware instead with the software :roll:
Got it to work now after a few games of poker cleared my head :)
