Seeking Generic AVR Development Board
19 posts / 0 new
Have put some research into development boards but am not satisfied with what I have found. Probably not looking in the right place.
I am looking for a generic development board which can handle a number of different AVRs.
If you know of a good development board resourse please let me know. Here are some the resources I have found.
Digilent
http://www.digilentinc.com/Produ...
MicroController Pros
http://microcontrollershop.com/d...
Futurlec
http://www.futurlec.com/AT8535De...
SparksFun Electronics
http://www.sparkfun.com/commerce...
MicroControllerPros
Olimex
http://www.olimex.com/index.html
Thanks.
sundownr
All of us can help make a better world simply by taking better care of children
Good resource. Hope you add to it and "publish" it again.
Good idea but I would like to believe there are much better lists than mine.
I drag all worthwhile information I find on the Internet into OneNote which automatically indexes everything. Then I can recall whatever I like whenever I like.
Maybe this list can be tweaked into something really worth while. Let's see what happens.
sundownr
The link for futurlec is for the At90
futurlec's best AVR dev board is
http://www.futurlec.com/ET-AVR_S...
You also need a stamp module for it
Add in a JTAG clone
http://www.futurlec.com/ET-AVR_J...
For about $65 USD you get a kickass dev kit, complete with a hardware debugger.
The dev board has a breadboard area so you can put in pdip if the Atmega8128/64 Stamp module is not to you liking. Alternatvely you can just buy the stamp module and not get the devboard.
I cut my teeth with the exact same setup. After about 2 weeks I gained enough confidence to just use a breadboard and AVR PDIPs and ganed enough knowledge to make the choice of using the atmega48/88/168 series.
So we need 2 lists.... devel boards that accept more than one type of AVR (like an STK500?), and devel boards that are nice and general in the io dept, but just use one type of avr?
bobgardner
Good point... I am looking for a development board with USB capability. I have the AT90USBKEY but it is a demo product lacking functionality like A/D reading.
I also need to experiment with the ATtiny261 or similar AVR which can be used to read temperatures.
In short I need to find a diversity of development boards to experiment with a diversity of projects.
Hopefully this development board list will expand to accommodate all of us. The list has grown considerably in only an hour.
We AVR newbies' could also use some commentary on development board usage. Being a programmer I have few problems with code... it the hardware architecture and shear number of AVR options which tend to slow me down.
I should also note it is the shear number of AVR options which confound the choice of development boards. This is where I specifically need advice. Certainly 1 development board does not do it all... so where is the best place to start?
sundownr
If you have a Dragon, these two add-on boards will let you work with several different AVR families:
http://www.ecrostech.com/AtmelAvr/DragonRider/index.htm
and
http://www.wizbangdesigns.com/10018_10019_PCB.html
And of course, there's always the STK-500 and STK-600
Randy
As you've pointed out, one board might not be comprehensive enough to deal with all your wish lists. About an 18 months, I too had similar requirements, and finally settled for this board:
http://hubbard.engr.scu.edu/embedded/avr/boards/#avrminiv40
Cheers,
Vignesh
If everything seems to be coming onto your way, then you are probably driving on a wrong lane..
I still believe it's the Atmel STK500. If you need to connect it to your PC then throw in an off the shelf USB-RS232 cable too.
If your budget allows then STK600 is nice but watch out for the additional cost up for all the different routing cards/sockets you may require. The STK500 will take all the DIP packaged AVR8s as delivered.
Seems like a good board, too bad it doesn't appears to be manufactured any more.
that vendor's assortment of I/O modules is unique and great
It seems to me the first requirement to find the right development board is that you have to understand what it is you want to accomplish in the first place.
This is probably why professional AVR developers insist on understanding the data sheets before anything else. Once you understand a few basic data sheets then finding the right development board should be a much easier task.
Anyway... we seem to have come up with a reasonably good list of AVR development board resources.
I forgot to mention the Butterfly development kit sold at http://www.smileymicros.com
Thanks for the help.
sundownr
FWIW,
You really cannot get more generic than the STK500
Then, if you need a few 'extras' you pop on an STK501, 502, etc.
jsundownr: see this thread https://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=66986
My vote is for the STK500 as well.
Nard
His commercial website was procyonengineering.com but seems that it is defunct now.
Cheers,
Vignesh
Thats the problem. Mr. Pascal Stang (designer of this board) has written excellent AVRlib, but he is very hard to catch through e-mail. You could try calling him over phone though. But this board is worth its money.
Cheers,
Vignesh
I'd really like to know what happened to Pacal Stang also. I'm speculating that he is in graduate school and hasn't the time to follow up on his earlier stuff, but I don't know for sure. He did leave behind a lot of good stuff though.
Smiley
I believe he graduated in 2003 or 2004, because I can vaguely recollect his name in the final year list during that year, I am not sure.
AVRlib is a boon to starters. I was inspired by the leven of documentation he has brought in, and clever usage of doxygen.
Cheers,
Vignesh
