Using alias names for registers
6 posts / 0 new
I want to call TCNT0 with a more understandable name like Timer0Count. So I did the following declarationin my code
#define Timer0Count               _SFR_IO8(0x26);
But it doesn't work. I also used
#define Timer0Count               TCNT0
Can any body help, how can I define these registers in my code, without modifying the WINAVR headers.
Thanks in Advance
smartsarath2003
What exactly do you mean by 'not working'?
Does the code sit and wait for a member of the labour union to show up? Does it not compile? Does the chip explode? Please be more specific.
The code you posted looks OK for me, but I would strongly suggest to use the second variant, for clarity and portability.
Thomas
(edit: spelling)
pycrc -- a free CRC calculator and C source code generator
You'd still need a:
#include
or at least a:
#include
But like Thomas says "doesn't work" is not a lot to go on!
To clear, my code does compile with the above defines. I am getting errors when I assign any values to it like:
Timer0Count = 64;
The Exact error I am receiving is
Error: expected expression before '=' token
When I replaced Timer0Count with TCNT0, the error gets cleared and I can compile.
Don't put a semi-colon at the end of the #define.
Your second snippet of code looks OK, though. If in doubt, post a piece of code that gives you the error.
To explain further, the #define is (in simple terms) an instruction to the pre-processor to replace one symbol with a different string. So your code:
Timer0Count = 64;
was replaced by:
_SFR_IO8(0x26); = 64;
See? :D
Of course, this gets more complicated when you get to #define ("macros") with arguments - "macro functions".
I found the following tutorials on C macros:
Macro tutorial and Macro Functions
Stu
