I just received my first AVRISP mkII and discovered it only comes with a 6-pin female connector on the DUT end (as I recall, the original version let you use a 6-pin or 10-pin). I use RJ-12 connectors on my boards for programming and built an adapter that converts the old 10-pin connector to RJ-12 (see attachment), so I need to make something similar for the new 6-pin connector. The problem is I can't find any 2x3 connectors (at least at Digikey or Mouser), male or female. Can someone point me to a supplier for a 6-pin IDC shrouded pin connector?
Thanks.
